Old 05-31-2015, 09:15 AM   #1
wpgman19's Avatar
What pressure should my tires REALLY be at?
I am a newbie pulling a Rockwood 8310SS, with a dry weight of 7200 LBS. The tires state a MAX PSI of 50. I was concerned about inflating to 50, especially when the TT is loaded, as the fear of a blowout at 100kph (60 mph) freaks me out. The tires do look a little low and the gauge indicates they are at 44-46 LBS each. Should I bring them to 50 before I hit the road? What is right?
2014 Rockwood 8310SS Diamond
2014 F-150 Super Cab Ecoboost w/Max Tow
Nights Glamped - 2015 - 24
Nights Glamped - 2016 - 4
wpgman19 is offline   Reply With Quote
Old 05-31-2015, 09:18 AM   #2
fonzie's Avatar
top up to max PSI on tire, so 50 psi cold
Fonzie
Old 05-31-2015, 09:22 AM   #3
Ford Idaho's Avatar
Agreed!
There is more than enough built in allowance for air expansion.
Old 05-31-2015, 09:25 AM   #4
wpgman19's Avatar
Thank you both!
Old 05-31-2015, 09:29 AM   #5
fonzie's Avatar
Originally Posted by wpgman19 View Post
Thank you both!
Also you should have info on driver side front trailer like this....
Name:	Rockwood 8319ss.jpg
Fonzie
Old 05-31-2015, 09:42 AM   #6
B and B's Avatar
Hello, I used my stock tires for a year than upgraded to some Goodyear. There are many horror stories on here with blowouts etc. Just make sure you keep an eye on pressure and more so the loading. Tow level as to not put strain on the back axle towing high.
Hope to make it out west in a couple summers and enjoy your part of Canada.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 05-31-2015, 02:08 PM   #7
Evereddie's Avatar
What brand of tires do you have?
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Evereddie is online now   Reply With Quote
Old 05-31-2015, 02:22 PM   #8
This system is indispensable.....IMHO....
Unencumbered By The Thought Process
tande is offline   Reply With Quote
Old 05-31-2015, 03:59 PM   #9
Definitely inflate your rear tires on your tow vehicle to the Max pressure, cold, as indicated by the information on the side of the tire. This also pertains to your trailer tires, Max pressure, cold, regardless of how loaded it is. Especially if they are not load range "E". I would also bump the front tires of the tow vehicle up 10 Lbs over usual.
The primary reason for blowouts on tow vehicles and trailers is LOW pressure, not high pressure. When a tire is under-inflated their is more "rolling resistance" between the tire tread and pavement and this increases the tire temperature which then leads to tread separation or side wall failure and a blow out. So MAX pressure when towing.
Another thing, when you replace your tow vehicles and trailer tires, always buy "E" load tires. These are ten ply tires and will provide extra protection against blowouts and pots holes. I just returned from a 5K mile trip back and forth across the US. Have load range "E" tires on both my PU and 35 ft. 5th Wheel. Before we left I inflated the rear tires on the truck and all 4 tires on the trailer to 80lbs. We hit some of the worse roads I have ever encountered back East with huge pot holes, many of which could not be avoided. I was sure, on several occasions, that the truck or trailer tires where going to definitely blow as hard as we hit the pot holes. Never had one single tires issue during the entire trip. Load range "E" tires are definitely worth the additional safety and the little extra price for the piece of mind they provide.
usraptor is offline   Reply With Quote
Old 05-31-2015, 04:07 PM   #10
BBBlue's Avatar
Originally Posted by Ford Idaho View Post
Agreed!
I maintain 110psi in my Goodyear 614's, which is the maximum sidewall pressure cold. When traveling, my TPMS will show an increase up to at times 128 psi. How much over the maximum sidewall pressure cold before getting concerned?
BTCM(SW) Ret USN
2013 Sanibel 3500
2013 Ram Truck 3500 Laramie Longhorn Dually
2017 Days camping-190
2018 Days camping-66
BBBlue is offline   Reply With Quote
pressure, tire, tires
