Old 06-16-2016, 09:39 PM   #41
Iwannacamp's Avatar
What type of jack for TT emergency use
I got a shorty and had to swap. It would have jacked it, but the stem had to be screwed way out. I would suggest a quick measure.
BTW I had both...hoping to never use either.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 06-16-2016, 10:38 PM   #42
Tom48's Avatar
Originally Posted by SeaDog View Post
I carry a lite weight floor jack in the bed of my truck when pulling the TT or my boat. The reason I want a good stable jack if I'm going to pull a tire.
I fast learned that a small floor jack (sold as 2 ton) barely lifts an axle when each wheel is load rated for nearly 3000 and killed me doing it so now it's an 8 ton bottle jack with wood between it and the axle, right on the u bolts. Easy as can be.. May be if I am prepared, with TPMS AND NEVER LET MY TIRES GET OLD, , I will never have a flat again. Knock on wood.
Tom48 is offline   Reply With Quote
Old 06-17-2016, 11:13 AM   #43
I use 2 bottle jacks 1 dissent lift high enough tnen put blocks on the second one to get it up.
NorSnrub is offline   Reply With Quote
Old 06-17-2016, 11:44 AM   #44
Originally Posted by northstar1960 View Post
you can get a nice 6 ,8, 12 ton bottle jack takes up very little room and will lift you r unit off the ground . much safer then a car type jack with the power to do what's needed . HF has them for around $20.bucks
X2- Carry a 12T bottle Jack and always have blocking for my tongue Jack so good to go.
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2013 22 nights.2014 57 nights.2015 116 nights
2016. 96 nights 2017 72 nights.
Filterman is offline   Reply With Quote
Old 06-17-2016, 12:19 PM   #45
I think that blocking up the tongue jack is very important if you're not hooked up to the truck and changing a tire.
My dealer was setting up my windjammer hitch when I bought it and the tongue jack just collapsed and barely avoided hurting him seriously. I'll never trust another one after seeing that. He's lucky he didn't break a leg or arm. Cost him money since he had to put a new one on for free then.
Matter of fact when I leave this trailer in Florida I'll probably put something under the tongue jack just in case. If it collapsed it would ruin my front stabilizers.
2012 Windjammer 3001W
2016 Sunset Trail Super Lite 250RB-For Sale
2015.5 Chevrolet Silverado 2500HD LTZ crew cab Z71 4x4
KingFisher is offline   Reply With Quote
Old 06-17-2016, 10:44 PM   #46
I have a trailer aid but have only used it when off the pavement. Otherwise I've used a 10-ton bottle jack placed on the frame between the two axles. My concern with the trailer aid, which may not be merited, is that putting double the weight on one of my two torsion type axles might damage it. My torsion axle rating capacities have little to spare when the trailer is normally loaded. Does anyone know if 30 minutes of near 100 percent overload for a flat or even several hours for a wheel bearing replacement is taking a risk of damaging a torsion axle?
Paul12 is offline   Reply With Quote
Old 06-18-2016, 02:26 PM   #47
Originally Posted by NCBBA11043 View Post
X2 - had to use it twice in one week! Less than 15 minutes to change a tire on the PA Turnpike (on an incline!)
Yes thats good. Better still call AAA or CAA and get them to come and change it. The're there and away in little more than an hour usually.
bruane is offline   Reply With Quote
Old 06-19-2016, 01:04 AM   #48
duradiesel's Avatar
I just call Good Sam & tell them to change the tire . At home I do my own .
2006 GMC Duramax Extcab LB
2012 Wildcat Sterling 32RL
duradiesel is offline   Reply With Quote
Old 06-19-2016, 06:25 AM   #49
Camper Newbie
Using Jack?
On our most recent trip I got a flat tire. Stored was the "Trailer Aid" so I went ahead and used it. I was impressed on how easy it was to lift the trailer. Worked well on my duel axel, 21 footer travel trailer.
R&R in Florida is offline   Reply With Quote
Old 06-19-2016, 06:57 AM   #50
Unencumbered By The Thought Process
tande is offline   Reply With Quote
