Old 06-16-2016, 08:36 AM   #1
What type of jack for TT emergency use
I recently purchased a Wildwood 27RKSS and the dealer informed me that there was no jack with it that I'd need to use the truck jack in order to change any flat tires.
I'm sure that would be a painful process at best.
So...I purchased the Andersen Rapid Jack. Looks easy enough to use. However, I question whether it would be suitable in every instance I may find myself in.
Any recommendations regarding the type of jack and capacity I should get?
Trailer is about 6500 lbs empty, probably 7500 lbs full.
seakayaker is offline   Reply With Quote
Old 06-16-2016, 08:39 AM   #2
SeaDog's Avatar
I carry a lite weight floor jack in the bed of my truck when pulling the TT or my boat. The reason I want a good stable jack if I'm going to pull a tire.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 06-16-2016, 08:47 AM   #3
capacity?
What capacity floor jack would you recommend?
Old 06-16-2016, 08:57 AM   #4
I got one of these after my truck Jack wouldn't lift the trailer
Name:	ImageUploadedByForest River Forums1466085441.454745.jpg
It's called trailer aid
missing_link is offline   Reply With Quote
Old 06-16-2016, 08:58 AM   #5
Pickin' & Campin'
Please be cautious with 'light weight floor jacks.'
While they do provide a bigger footprint for stability than say a bottle jack, usually those that are considered light weight units (1 or 1-1/2 ton) would make me squirm working under or around them on a 6000+ trailer. Might be OK for a pop-up/hybrid though.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 06-16-2016, 08:59 AM   #6
SeaDog's Avatar
I carry a 2 ton jack. I have not tried the drive on products because my boat trailer only has one axle. (when I said lite weight I meant the actual weight of the Jack not its capacity)
Retired Navy
Old 06-16-2016, 11:22 AM   #7
I carry a 2.5 ton floor jack. When I had my flat it was all I could do to get my windjammer up to change the tire with this jack, 7100 pound dry weight on the windjammer.
Looking into getting a bottle jack.
2012 Windjammer 3001W
2016 Sunset Trail Super Lite 250RB-For Sale
2015.5 Chevrolet Silverado 2500HD LTZ crew cab Z71 4x4
KingFisher is offline   Reply With Quote
Old 06-16-2016, 11:52 AM   #8
ov845's Avatar
Attachment 111275
X2 For us it's the easiest way to lift without damaging the axles. I've seen people place the jack on the axle and lift bending the axle, not to mention the added weight of the floor jack.
Happy Camping!
2012 Ram 1500 Crew Cab 5'7" Bed
4 X 4 Engine 5.7L Hemi Gear 3.92
Airlift 1000
2015 2809W Windjammer (Diamond Package)
Husky Centerline WDH
ov845 is offline   Reply With Quote
Old 06-16-2016, 12:03 PM   #9
northstar1960's Avatar
you can get a nice 6 ,8, 12 ton bottle jack takes up very little room and will lift you r unit off the ground . much safer then a car type jack with the power to do what's needed . HF has them for around $20.bucks
northstar1960 is offline   Reply With Quote
Old 06-16-2016, 12:22 PM   #10
Same here 20 ton bottle jack and a 16" square of 3/" plywood small works great.
Myrle is offline   Reply With Quote
