07-19-2013, 07:52 AM
#41
Originally Posted by Mister
Off subject here but ST tires don't impress me in the slightest. Why oh why has a tire manufacturer not grown a brain and manufactured a limited series on LT tires in 15". It seems most trailer manufacturers run 225/75R15 on larger trailers with D or E as appropriate. Just seems like a sure fire sell if it's by a quality name with a quality build tire. Case and point, look at all us Maxxis fans... Just imagine if we had the comfort and peace of mind of a heavier duty more rugged and better rated tire for both load and speed.
Trailer tires are specially constructed for the job they are designed for, and usually have a higher load-carrying ability than LT tires.
So I would rather have a D-rated trailer tire than an LT tire any day.
But yes, we do have a very limited choice when it comes to tires.
07-19-2013, 12:44 PM
#42
We are putting some miles on this weekend. Going to Joplin Arkansas to Lake Ouachita Hoping for a great trip.
2008 Jeep Grand Cherokee Diesel
2013 Salem Cruise light 19bh
Hensley Cub hitch ,
07-19-2013, 12:53 PM
#43
...Why oh why has a tire manufacturer not grown a brain and manufactured a limited series on LT tires in 15". It seems most trailer manufacturers run 225/75R15 on larger trailers with D or E as appropriate. Just seems like a sure fire sell if it's by a quality name with a quality build tire. Case and point, look at all us Maxxis fans... Just imagine if we had the comfort and peace of mind of a heavier duty more rugged and better rated tire for both load and speed.
Didn't know you were restricted from putting any tire you heart desires on your trailer. Your trailer is yours, you can do as you please as long as your hip pocket can afford it.
07-20-2013, 09:55 AM
#44
Wish I would've done tires before the hitch. The hitch made a big difference but the tires did the same. Not sure I could've got by with tires and old hitch.could've should've.
Hensley Cub hitch ,
07-21-2013, 08:46 AM
#45
Yeah and there in lies the problem. Most tires I want would require a rim swap as well... And I work for living
2008 F150 FX4 5.4L & 3.73s
2014 PTM Tracer 3200BHT
Yes...I've finally made it to Prime Time!
07-21-2013, 09:00 AM
#46
We found out over the years to just buy what we want like wheels, etc. is to buy one at a time rather that try to get everything at one time. Same amount of money, maybe a little more, not as painful, but sure easier on the budget.
07-21-2013, 09:11 AM
#47
On my second season with the Kuhmo 857's, and I like them. Seem to tow very well, they build pressure with road heat-up, but no more than 10 psi, and I've had no problems....
One word of caution/advice (that I got from others, and am just passing along): Look for the psi rating on your TT wheels. Some are only rated at 50 psi, which is well below the 65 psi that the 857's run at.... I also changed my valve stems to the brass type to accept both the higher pressure and the TPMS senders.
Fire Instructor
2022 Coachmen Leprechaun 319MB
2022 Ford Ranger toad
07-21-2013, 06:33 PM
#48
Yea we put the high pressure valve stem. The wheel I didn't check that but we are running at 57 pounds of air. Max air is 65 we are under on the weight by alot. My trailer is 3000 pounds and we pack light. So I think we are better than we were. We had the cheap O tires. Time will tell but we are learning the hard way. I will check the wheels.
Hensley Cub hitch ,
07-23-2013, 07:31 PM
#49
Just got the Goodyear HMG2020s put on today. Turns out the tread pattern really is quite different from a standard trailer tire. Pics to follow.
2009 Roo 21RS
2010 GMC Sierra 1500 w/ tow pkg
Nights camped in 2014:29 | 2013:33 | 2012:32 | 2011:33 | 2010:30
07-24-2013, 06:40 PM
#50
Here's a pic of the tread pattern on the Goodyear HMG 2020. Quite a bit different, but seems to ride just great.
2009 Roo 21RS
07-24-2013, 06:54 PM
#51
Did you have your new tires balanced?
2013 Palomino Columbus 320RS
2007 Dodge RAM 2500 6.7 Cummins
Reese 15K manual slider
Prodigy
M.I.L. in Florida for good!!
07-24-2013, 09:00 PM
#52
I'll let the picture answer that one! ;-)
But I did get questioned when I told him I wanted them balanced. But, hey, the customer is always right, isn't he?
2009 Roo 21RS
08-03-2013, 02:29 PM
#53
Got over 3000kms on the new Goodyear HMG2020s and all is good so far. Only issue we've had is that the trailer bounces more on rough roads as these D range tires have more PSI in them than our old C range OEMS did. But so far, I'm pleased with them. Of course, they were the only load range D tire in this size that I could easily get my hands on in Canada, so I can't compare them to the Maxxis.
2009 Roo 21RS
08-04-2013, 08:20 AM
#54
Sorry I should've been more specific. A 15" LT in the D and E ranges. The construction just seems better and the tires themselves are heavier (bigger is better right? ) than there ST counter parts when you get into size ranges where you can do apples to apples comparisons between ST and LT of the same load range. I recently read a very interesting post on another forum about reserve rating in the LT class that made a lot of sense assuming it's not internet non-sense. After all who would ever make something up or mislead anyone else on the internet...
