Old 09-18-2015, 05:27 PM   #1
JimOneil43's Avatar
Wheel Balance with TPMS ?
When you install a TPMS system, such as the one with the flow-thru sensors and also if you install tire valve stem extenders, is it necessary to get the wheels re-balanced on a Motorhome?
Retired and loving it...Can't wait to get back on the road!
2017 Forester 3051S ("Farley")
Born April 18, 2016
Toad: 2014 Honda CR-V AWD
GO DUCKS !!
Jim & Diana (and 3 cats)
JimOneil43 is offline   Reply With Quote
Old 09-21-2015, 11:57 PM   #2
My sales man said that the weight of the tpms would compromise the valve stem causing a leak.
Conde98 is offline   Reply With Quote
Old 09-22-2015, 12:47 AM   #3
JimOneil43's Avatar
A lot of people are using these systems....there must not be too many problems with them. I would think that with metal valve stems you wouldn't have a leaking problem. Anyone have an answer about the wheel balance question?
Born April 18, 2016
GO DUCKS !!
Old 09-22-2015, 01:03 AM   #4
coupevillefish's Avatar
We had the TST valve stem extensions installed at Les Schwab. They riveted a clamp to the wheel cover to keep them from flopping. Balancing is not an issue because we have the beads.
coupevillefish is offline   Reply With Quote
Old 09-22-2015, 01:26 AM   #5
DaveSchwartz's Avatar
I had the wheels balanced with the TST 507 flow-thrus on when I upgraded the tires. Rubber valve stems (same ones as my 80PSI LRE TV tires, same tire dealer). Have had no problems in about 6,000 miles of towing with interstate speeds up to 65mph.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 09-22-2015, 07:32 AM   #6
I had all metal stems installed and the wheels balanced with the non flow through sending units installed. It used to be recommended that the stems be changed to metal, I am not sure if TST still recommends this.
Filthy Beast is offline   Reply With Quote
Old 09-22-2015, 07:39 AM   #7
RSchleder's Avatar
I can't speak to the question of balancing when installed on a motorhome. However, on my 33' Wildcat MAXX 33' TT, I had metal stems installed and balanced per the owners manual when I installed the non-flow thru sensors.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 09-22-2015, 07:39 AM   #8
Had the high pressure rubber valve stems and 507 flow thru sensors that lasted a little over a year before a valve stem started leaking. Replaced with all metal, re-balanced with the sensors on. Found out it throws the balance off 0.5 oz. Did all 5 tires.
Old 09-22-2015, 01:18 PM   #9
JimOneil43's Avatar
Tell me about the beads. Are they put into the tires or what? And how expensive are they?
Born April 18, 2016
GO DUCKS !!
Old 09-22-2015, 01:29 PM   #10
ColoradoRick's Avatar
I had to get my rubber stems replaced because the depth of the threads wasn't enough to allow my TPMS sensors to work...but glad I did because I found the rubber things would leak air if just moved them a little bit...not good!
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
wheel
