Old 06-15-2019, 05:11 AM   #1
cajunmansion's Avatar
Wheel bearing grease
What type of bearing grease to use on my trailer?
cajunmansion is offline   Reply With Quote
Old 06-15-2019, 06:48 AM   #2
A32Deuce's Avatar
I use the same as I use on the vehicles that I drive that have greasable bearings. Heave duty for disc brakes.
I don't add to. I remove the bearings, clean then grease them with new seals, examine the brakes and adjust as needed. Then you know all is good and working.
A32Deuce is offline   Reply With Quote
Old 06-15-2019, 06:56 AM   #3
Camper
Technically you should use the grease that is specified and approved by your axle manufacturer. The approved list is different for LCI and Dexter.
In the end be sure to use a high quality grease. Any Lithium Complex NLGI 2 should be fine. Just clean out all the old grease before adding the new if you do not know what the old grease is. Mixing different types of grease is not a good practice as they can effect each other.
Lucas Red N Tacky gets a lot of recommendations. Mystic JT6 is another.
Thanks,
Brian
TV - 2006 F350 6.0 DRW CC
TT - 2018 Wildwood 31KQBTS
Macrosill is offline   Reply With Quote
Old 06-15-2019, 07:35 AM   #4
NMWildcat's Avatar
Lucas Red "N" Tacky.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 06-15-2019, 08:05 AM   #5
Mystic JT6.
Most of the axle manufacturers have approved grease on their web sites.
Days Camped: '16=46 '17=30 '18=51 '19=27
Old 06-15-2019, 08:13 AM   #6
Moparman1230's Avatar
Lucas “Red ‘n Tacky” here also.
"Do, or do not, there is no try." - Yoda
2017 Cherokee 294BH
2015 Ram 2500 4x4 6.4L V8 Crew Cab
Moparman1230 is offline   Reply With Quote
Old 06-15-2019, 08:24 AM   #7
Valvoline synthetic
https://www.valvoline.com/es-ecuador...nthetic-grease
2016 RAM 3500 DRW 4x4 LB LoneStar Edition
2018 Chaparral 360IBL w/Andersen Ultimate 2, Tireminder SMART TPMS, Swift Hitch SH04 WiFi Backup/Rear View Camera, Progressive EMS-HW50C
Prior Rig: 2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 06-15-2019, 08:32 AM   #8
SailorSam20500's Avatar
Another Lucas “Red ‘n Tacky”.
Al
Save the Earth. It’s the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 06-15-2019, 08:34 AM   #9
Flybob's Avatar
X4 Lucas R&T
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-15-2019, 09:07 AM   #10
A32Deuce's Avatar
Originally Posted by chaps2018 View Post
X2!
wheel
