05-30-2011, 09:27 PM
wheel bearings
i was wondering how many kilometer or miles should you have on your bearings before greasing them or adjusting them, i 4800 km on mine and i plan to take a 5000 km trip next month,,should they be looked at or just greased
thanks kevin
Kevin & Debbie and our little dog Emma
2004 F-150 Lariat 4X4 Ext Cab 5.4
2010 Flagstaff Shamrock Hybrid 19
05-30-2011, 09:30 PM
I would give the tire a tug and see if they are loose or tight
If tight maybe give them a shot of grease to make sure they are well greased and if you here the clunk from loose bearing then it's time to check them out before your trip.
This is my opinion and you will probably get many diffrent opinions on this one
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
05-30-2011, 09:51 PM
Al-Ko says inspect and repack annually.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
05-31-2011, 07:58 PM
Just had my first annual state 'inspection'. While not required by my state (Texas), I asked them to pull the brake drum at my extra cost. One of the brakes was found to not be working due to excess grease on the inside of the drum.
The grease came from the bearing being overpacked - pushing the grease past the seal (damaging the seal).
I was not really noticing any significant problems since 3 of the 4 wheels were braking, and I stay about 2k below my max load rating.
05-31-2011, 11:08 PM
I was told by the head mechanic at our dealer to repack every 5000km or anually, whichever is first. Come to think of it, I've been bad, I did 7000km.
Tow Vehicle: '92 F350, Crew Cab, 4X4, Cummins 5.9 24 Valve, 6spd.Driver:Clint, Navigator:Melanie, 1 dog (Great Pyrenees/Akbash cross) and now a cat too. Mission Statement: Just another adventure! Towed vehicle:2009 Roo 19 with lots of mods!
06-01-2011, 12:20 AM
If the bearings and seals are in good order there is no reason whatsoever to repack every 5000 km. Some years we have towed the trailer over 10 000 km and last year we did over 20 000 km without any problems at all. I do not use the grease fittings to add grease at all, once a year the wheels come of for a complete brake inspection and bearing repack.
Heinrich and Elly
2010 Prime Time Tracer 205M
2010 Dodge Dakota Crewcab 4.7 l
06-01-2011, 06:23 AM
In my case, my '11 Shamrock 19 has travelled approx. 8,000kms.
I just pushed new grease, using the zerk under the rubber cap. I used X-tra grease from Lucas Oil (from Canadian Tire), and it's green, I pumped until I saw the green stuff oozing out. I wiped cleaned as best as I could inside the cap and put the rubber cover back on.
I will pump a few squirts over the summer again and plan to remove the wheels and inspect either in the fall, or next spring.
Good luck.
Denis & Diane
* Happy Campers *
06-03-2011, 08:52 PM
That's great if you can do that. The point I made is that I do what was recommended to me by the dealer, and I will continue to do so until the warranty is over. I do envy you though, if you can pull your trailer for 20,000 km in one year, you do get out alot. Many don't even put that kind of diastance on their personal vehicle. Must be nice. My longest tow was the round trip from Vancouver to St. Laurent, Manitoba and back, plus a few shorter trips in between, in one season. Actually, I guess, closer to 9500 kms in total.
06-04-2011, 12:16 AM
We are both retired, so time is no problem and last year was an exception to the norm. In early summer we went to the Yukon and in the Fall to the East Coast including PEI. This year we will stay in Alberta and get to know this Province a bit better. (On my finance ministers orders)
Heinrich and Elly
06-06-2011, 10:14 PM
My family and I love visiting Alberta. Drumheller, Edmonton, Calgary, Red Deer, Rocky Mountain House, but Jasper most of all. Miette Hot Springs and the Ice Fields.....WOW.
02-09-2014, 03:44 PM
Update on NHTSA and the Brakes/Seals issue. Spoke w/ Tom Bowman again today at the NHTSA. He has been in contact with FR and the "ball is rolling." He did indicate that one (1) person filed a complaint after mine. While we were on the phone, his Boss came in w/ a bag of grease soaked parts that someone had sent him, but did not know if it was in relation to this matter or not. So, if you've had a wheel seal failure and you have had your brake assemblies replaced due to this issue, please file a complaint with the NHTSA, but be sure to include your VIN# so they can try and narrow the scope of the investigation to the affected series of axles. VERY IMPORTANT AND COULD SAVE A LIFE; MAYBE YOURS!!!
http://www.NHTSA.com
02-09-2014, 05:12 PM
I take it this has to do with the Lippert axels having the inner grease seal fail on the hub. Grease leaks out, gets flung all over the place via centrifugal force of wheel spinning. Grease gets on brakes and breaks eventually get weak, fail, etc. I have read about this on a few Forest River brands lately.
