Old 03-15-2015, 08:36 AM   #111
B and B's Avatar
Oh my. Nashville should be fun with stories of grease and offshore bearings!!!
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 03-15-2015, 08:42 AM   #112
Only if one bites the dust on the way.
Old 03-15-2015, 02:10 PM   #113
HOORAY, finally got all 4 of them done. Replaced all 4 inner cups, cones, seals, outer cups, cones, cleaned everything and only used 2 tubes of Lucas Red "N" Tacky grease. Hopefully this is the last time I'll have to mess with that dirty job. Lug nuts torqued to 110 lb/ft and hub caps left off for re-torqueing after 50 & 100 miles on the next trip.
Old 03-16-2015, 04:42 AM   #114
Witch Doctor's Avatar
Great glad to hear that you are done with the job, Well Alko sent all my bearings (4 sets) and rear seals cost 45.00 bucks. I should have gotten a few studs and lug nuts also to carry for an emergency, my reason so I won't get stuck someplace in the boonies waiting a week or 2 for parts. The parts list shows 1 size of studs for all there wheels no matter if they are 7" hubs or 12" hubs. The part I do not understand is that they call for 1/2"-20x1.8 long Knurl or short Knurl.
1) what is the Knurl ?
2) Parts list shows both
3) do you need to order both or just short or long
As anyone can tell I do not turn wrenches, except in an emergency. But it is good Idea I think to carry these parts and the Road Service could install if needed if I had the parts. So my question is what is meant by the word Knurl? Please educate me on this...Thanks in advance...
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-16-2015, 06:38 AM   #115
offroad's Avatar
To me, a knurl is a cross hatch pattern used for a grip.
http://en.m.wikipedia.org/wiki/Knurling
2017 Open Range - Light 297RLS, BX1 Gooseneck
2014 Ram 2500 4x4 CCSB 6.7L 68RFE
offroad is offline   Reply With Quote
Old 03-16-2015, 07:19 AM   #116
fonzie's Avatar
Different length knurl would be for different thickness of hub/rotor/drum...
Wheel stud - Wikipedia, the free encyclopedia
Fonzie
Old 03-16-2015, 08:57 AM   #117
Originally Posted by gljurczyk View Post
... The part I do not understand is that they call for 1/2"-20x1.8 long Knurl or short Knurl.
Did you get the cups and cones or just the cones? I think the short knurl would be what you want as the studs are recessed in the hub so the magnets don't hit them.
Old 03-16-2015, 09:14 AM   #118
Knurling - Wikipedia, the free encyclopedia
True,but also used to retain like in this application or for engine pistons to retain lube or reduce piston to bore slap! Old school! Youroo!!
Old 03-16-2015, 09:20 AM   #119
To Acadianbob. When you pump all that new grease into your hubs where dose all the old grease go?
martin73 is offline   Reply With Quote
Old 03-16-2015, 09:22 AM   #120
And valve guides to reduce clearance and allow better oiling of the valves. Old school also. (Plus it's cheaper than new guides. Lol)
bearings, wheel
