Forest River Forums
Sunline User Photos
Old 02-05-2012, 03:47 PM   #1
Dallas Texas
Wheel limit
Just want to confirm that the 80 PSI Max stamped into the wheel is the limit for the air valve and not the wheel. I plan on putting F load rated ties on these wheels. They require 110 PSI.
Cheers
2003 Cardinal 33CKT
2006 Ford SD F250 CC 4WD
2001 Coleman Santa Fe (to be sold)
1984 Honda Magna V65
1963 M50 Harley Davisdon
TexasBBQ is offline   Reply With Quote
Old 02-05-2012, 03:50 PM   #2
RJHuser's Avatar
Nope, thats the wheel rating
Rick & Debbie; Brandy, Dexter, & Fritz (The Doxie "Kids")
2011 Rockwood Windjammer 3001W
2009 Chevy Silverado 2500HD, 6 L Gasser; 12K Equalizer Hitch
RJHuser is offline   Reply With Quote
Old 02-05-2012, 04:54 PM   #3
Wheels rated for 80PSI, But your rubber valve stems are good for only about 50PSI.
donn is online now   Reply With Quote
Old 02-05-2012, 05:30 PM   #4
Dallas Texas
Drats, but thanks for the correction. I was hoping it wasn't so I could upgrade and go to F rated tires.
2003 Cardinal 33CKT
Old 02-05-2012, 06:23 PM   #5
sherdep's Avatar
you can still upgrade to F tires - you will just need to upgrade the Valve stem at the same time
to either a High pressure stem or a Metal Valve stem that allows you to go to the higher pressure
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (7)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 02-05-2012, 10:02 PM   #6
No matter what tire the OP places on these rims he is still limited to 80PSI. So upgrading tires is a waste of money. He would be far better off upgrading to 7K axles and 17.5 inch tire/wheel package.
Old 02-05-2012, 10:08 PM   #7
sherdep's Avatar
i thought F rated tires were 80 psi also just more ply then E rated - after looking they are 95 psi so i stand corrected
Old 02-06-2012, 06:47 PM   #8
Dallas Texas
The F rated tires i was going to get were 110PSI.
Upgrading to better axles isn't in the budget this year - maybe next time.
On the other hand, maybe I can find a good set of used wheels that can take 110psi.
2003 Cardinal 33CKT
Old 02-06-2012, 08:13 PM   #9
Lou Amadio
herk7769's Avatar
Cheers
From the looks of that stem; I don't think it is a "rubber" 50 PSI stem. It looks to me like a metal stem with rubber grommet. They are high pressure stems rated at 100PSI. I have them on my camper as well. The ones I have are plain brass so you can they are "metal;" other than the color they look identical to these and are rated at 100 PSI.
I use a TPMS that was bending the rubber OEM stems at speed and causing leaks. The metal stem does not bend with the pressure caps on so; no leaks.
Lou and Laura Amadio and Bella the German Short Hair Pointer
2010 Flagstaff 8526RLWS 5th Wheel Pullrite Hitch
(2009: 28) (2010: 74) (2011: 93) (2012: 7)
herk7769 is online now   Reply With Quote
Old 02-06-2012, 08:20 PM   #10
Those stems are rated for more than 80 PSI.
transamz9 is offline   Reply With Quote
» Online Users: 548
124 members and 424 guests
0721SSROO, 4bnabird, 4Jeeperz, 4runner freak, acadianbob, accumack, armye7, ashump, ayotte, BBuck, biggrigg, BigKidzFun, bignugget, BOBFIDY, briangoodridge, buzzmonster, Cafjackracing, caper, cat1956, cdbus, chof16, comfun1, Cowracer, D-mo, DAISY BOYKIN, darkcloud, daveg, daw592, Dennis and Julie, dewcew72, dezeldad, DonG, donn, dtolar, dunnnc, Elidh, etbt1216, extremebike, Falcon35, flc, Flying dutchman, fordmantpw, FR28footer, frfan, GeorgieGirl, gerrym51, Great Horned Owl, gvanmeter, herk7769, hitch hiker, hoovercab, Indy Steve, J McClure, Jeep4Two, Jestercyco, jjm901, JMF, jmswms, JoeR, jusme, kentkings, kgmat, KKapa, Kricket, lbhird, lemoj1, LFugate, lmcleister, Lonewolfcry, lowbubba, mayorvic, mcbride5, merlin66043, mike7431, MikeFresno, MilCop4523, Mkayers, Mnflyboy, MREZ, mrtodds, msbates, NeilM108, newby, nuisance, OffPavement, pg_rider, Pinesman, pmsherman, redfox217, Reneedann, retiredguy, Rickstermn, Rugged Brown, rvinman, SabreSam, Sailfish Bret, Sawdr73, shineysideup, Skabi, skipper194242, slogan, softwarejoe, southernsky, Stank Bait, Tee, tentcamper1, tessval, THELMALOUIE, tiny, tking01_2000, torben, TRAVLINOHIO, travyp, Triguy, tshayn, vlite2011, vp22er, wagon52, whj77372, wildwood_man, wnytaxman, wolfpack21643, wpmcnutt, youroo
Most users ever online was 996, 05-22-2012 at 11:04 AM.
Close [X]
