04-27-2016, 12:07 PM
Wheel torque on my trailer?
My 2015 Vibe is about to get a full wheel bearing repack this afternoon, and I havent been able to figure out what the wheel/rim retorque is supposed to be. Anyone know? Really dont want to guess.... thx!!!
2015 Forest River Vibe 268RKS being pulled by a 2010 F150 Lariat 5.4l, 3.73 axle Super Cab, Max Tow with 11,300 lb tow capacity , Equalizer 4 point W/D hitch
04-27-2016, 12:36 PM
The sticker on ours says 90-95 ft lbs.
2003 GMC 2500 HD 8.1 & ALLISION TRANSMISSION
2000 SIERRA 30 ft FKSS
04-29-2016, 01:11 PM
I'm going to guess 90 to 100 ft lbs. However, recommend you pull down a Lippert or Dexter Axle manual it will give you the torque valve for each size wheel stud.
George Scott
2015 Salem Hemisphere Lite 272RLIS
2006 Heartland BH 3400/Summer Home
2021 Sabre 37FBT
04-29-2016, 02:22 PM
Who Dares, Wins
The amount is different whether Aluminum or Steel I believe. 95 to 110 for steel is what I have always read.
2015 Chevy HD D-Max
2022 Impression 315MB
04-29-2016, 03:35 PM
I use 90 on my aluminum rims. Important thing is to re-torque at 25 miles, 75 miles, 175 miles, 375 miles and then after that before each trip. Seems like about 500 miles on my trailer before before I no longer have one or two that still tightens at little.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
04-29-2016, 08:15 PM
Mine are aluminum. Seems strange that forest River didn't put a sticker on the trailer right above the wheels with the torque spec.... Kind of an important thing to know....
04-29-2016, 08:16 PM
Who Dares, Wins
Mine HAD one until it peeled off withing a few weeks. It was only a paper sticker, not so good.
2015 Chevy HD D-Max
04-29-2016, 08:21 PM
FWIW, lug nuts/studs don't know the difference between steel and aluminum wheels.
04-29-2016, 08:22 PM
Mine did. Paid attention to the spec, 100 pounds torque. Went and bought a cheap torque wrench and set it at 100 and keep it in the case, only use it for that. A little anal but it makes me happy.
No worries...
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
04-29-2016, 08:26 PM
Who Dares, Wins
Not doubting your knowledge / expertise but, from what I have seen AL is 90 to 100lbs, steel 90 to 120. Must be reason somewhere. AL softer so less to avoid squishing? I dunno?
2015 Chevy HD D-Max
04-29-2016, 08:47 PM
The rims know the difference.
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
04-29-2016, 09:05 PM
Who Dares, Wins
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
Guess That answers that..
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 Chevy HD D-Max
04-29-2016, 09:10 PM
Mine said 120 - 140,,
Don't forget to return the wrench to zero or near zero or calibration will suffer.
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
04-29-2016, 09:17 PM
That I did not know. Thanks.
Bob & Michelle
04-29-2016, 09:26 PM
Mine don't, I've been torqueing to 110 lb/ft for the last 8 yrs on the same alum rims. Seems to be working. Haven't cracked a wheel or lost one yet.
04-30-2016, 12:23 PM
Put new tires all around last year and we checked it on line at the tire shop and on our 16" aluminum wheels it was 95. checked them twice after and only once was there any slack to pick up. I carry a 1/2" torque wrench at all times.
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2014 57 nights.2015 116 nights .2016 96 nights .2017 72 nights. 2018 157 nights. 2019 52nights.2020/21 118 nights. 2022 115nights
05-02-2016, 07:43 PM
Aluminum and steel wheels flex differently and therefore may be seated differently against the hub so that is the reason for the different torque values and re-torque requirements. I torque my 15" aluminum wheels to mid-spec of 95 ft-lb per the mfg values.
Also, as was stated earlier, don't leave a torque wrench tensioned or completely relaxed as it will affect it's calibration. Store with a setting of 10 to 20 ft-lb is best.
Ted
2017.5 Cedar Creek 34RL2
2018 F-350 Lariat CC SRW PSD 4x4
USMC Fighter Pilot (Ret)
05-03-2016, 06:12 PM
2010 F250 5.4L 3.73
Equal-i-zer 4pt 12K
I sure have been doing it wrong. I've never checked mine in 10000 miles.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
05-04-2016, 01:27 PM
Great comments! Looking like torque in the 90-95 ft lb range is where I'm going. Thanks for all your input.
05-04-2016, 01:34 PM
This says between 90 lb/ft to 120 lb/ft. I tighten my lugs on the aluminum wheels to 110 lb/ft.
BTW, they state ft/lbs which is technically incorrect. Horsepower is measured in ft/lbs, torque is measured in lb/ft.
