Wheels for the G614
I rotated my fiver tires this week, and examined the back side of the wheel looking for a pressure rating. All I could find is the load rating of 3200 psi in the casting. I believe this will make it an 80 psi max wheel. I have searched high and low for a 16" x 6" six lug wheel that is rated higher than 80 psi. Not sure what others have done in this regard.
The only option I've found would require buying polished chrome steel wheels. They don't look as good as the aluminum, but certainly, its is an option, and they are about half the price of aluminum.
Has anyone found a decent aluminum wheel that matches the 6 lug pattern rated higher than 80 psi?
I'm not sure if they make an 8 lug hub that fits my axle/brake assembly, and I sure don't want to swap axles just to accommodate the G614's.
man, none of this is easy...or cheap.
Thanks in advance for your thoughts.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
