Old 01-15-2010, 06:42 PM   #1
fivecodys's Avatar
Where to place Jack Stands during wheel work.
I am planning to repack my wheel bearings and adjust my brakes.
I was curious where to place the jack stands?
I am not comfortable with just the jack holding up the axle while I'm under there snooping around.
Any suggestions?
Bill
2009 Flagstaff 8528 RKSS
2007 Toyota Tundra DC 5.7L V8
Pullrite Superglide 14K
Air Lift 5000
Prodigy Brake Controller
"I've got a mind like a steele.. a......a steele......um.....uh...... what's that thing called again?
fivecodys is offline   Reply With Quote
Old 01-15-2010, 09:07 PM   #2
powerboatr's Avatar
i have in the past placed the jack stands in front of the front axle at the frame and then behind the rear axle at the frame, then support each axle with a small jack to prevent the springs from hanging free, it wont hurt em but makes it easy for you to adjust the work height of the hub as you go along.
Living in the Piney Woods of Texas.
powerboatr is offline   Reply With Quote
Old 01-18-2010, 04:31 PM   #3
I use a 4x6 piece of wood to lift both axels evenly. Then I place jackstands under both axles close to the frame.
turbopuppy is offline   Reply With Quote
Old 01-19-2010, 06:32 AM   #4
if you are jacking it from the axle, put the axle stand under the axle. if you jack it up from the frame then put an axle stand close to the jack on the frame. make sure to lower the jack and put pressure on the stand while working.
skidoonut is offline   Reply With Quote
Old 01-19-2010, 07:31 AM   #5
MtnGuy's Avatar
I don't think you would want to do that if you have torsion axles.
Old 01-19-2010, 10:00 AM   #6
i have torsion axles on all my trailers. they are just as strong as any other axle.
Old 01-19-2010, 11:54 AM   #7
MtnGuy's Avatar
I agree. I have torsion axles on my Surveyor, and had them on my Trailmanor, and they are great. But I have read on several forums that if you have that type of axle, you should not jack up the trailer by the axle.
Old 01-19-2010, 07:02 PM   #8
fivecodys's Avatar
Then by what? The frame? Where on the frame is what I am looking for here guys. Help!
Bill
Air Lift 5000
Old 01-19-2010, 08:36 PM   #9
1st question, if you're not sure about how to jack up the trailer, are you sure about doing you're brake work? As for torsion axles, there is no such thing. It a is a "torsion bar suspension" , and you don't want to jack it up by the torsion bars. You risk bending the bars and knocking the axles out of alignment. The simple answer depands on your jack. If it will go low enough to get under the axle and lift the wheel, then jack it up by the axle, one wheel at a time, and place the jack stand as close to the jack as possible, and then let the jack down to put pressure on the jack stand. Once you have one wheel suspended, then move the jack to the other axle and do the same thing. Now you have one side in the air. Make sure to loosen the lug nuts before you jack up the wheel, LOOSEN ONLY, DO NOT REMOVE. Block the wheels on the other side, front and rear. For an extra measure of safety, once you have the wheels in the air, lower the stabilizer jacks to the ground. Remember they call it "pack" bearings because there is more to it than rub some grease on them. You also need to know something about electric brakes and the things to look for, beside normal shoe wear. Theses are not car brakes, but just like car brakes, your life and mine depend on them. Hope this helps, and please make sure you know what you're doing so you don't create any problems for yourself or others.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 01-19-2010, 10:06 PM   #10
milzat's Avatar
I placed a jack between the tires, lifting on the frame. Note wooden blocks under jack.
Click here
milzat is offline   Reply With Quote
