04-25-2018, 06:12 PM
Where to wire repeater for TST TMPS on trailer?
Just got the new TST 507 today. They now come with the repeater. Not sure I'll need it as trailer is 30 footer, but directions just say to wire to any 12 volt source. Electrical and me aren't fast friends. I pulled some videos but they primarily dealt with motorhomes and larger fifth wheels that had enclosed battery banks. The batteries on my trailer are outside the coach in boxes on the tongue. What would be the best location to wire in the repeater given I can't go directly to the batteries? Thanks.
Brian and Tracy
2017 Flagstaff 26FKWS
2019 GMC Sierra 2500 Denali
6.0 Gasser 4:10
04-25-2018, 06:33 PM
Who Dares, Wins
I mounted my repeater for the Tireminder tpms under where the aframe meets the main frame. I wired it into the junction box under there. Worked well on our 30ft tt.
2015 Chevy HD D-Max
2022 Impression 315MB
04-25-2018, 10:52 PM
Truck System Technologies Rep
Tst tpms
Just hook the repeater to the battery in the front of the trailer. Once connected to the battery leave it in the battery box, and close it up.
Thanks, and feel free to call me anytime at 210-420-0132
Best,
Mike Benson
04-26-2018, 08:34 AM
Best,
Mike Benson
Question for you.
With the repeater wired "hot" on the battery, how much power will it drain in between uses? I was thinking of putting a switch on the outside to turn it off when not in use.
Mark
04-26-2018, 12:26 PM
My batteries are still in storage but I keep my repeater inside the battery box. I put a little toggle switch on battery box with light and just flick it on when I connect and off when I disconnect trailer.
04-26-2018, 12:30 PM
I mounted the repeater on the post for the propane tanks where it is protected under the tank cover. I then ran the electrical connection down to the battery box where I use 2 alligator clips to connect/disconnect.
04-26-2018, 12:59 PM
If I add a repeater I will wire it to the running lights as I always run them for the camera anyway
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
04-26-2018, 01:01 PM
Georgia Rally Coordinator
I mounted the repeater on my V-nose just above the battery box. Wired in with on and off switch attached to the battery box. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
04-26-2018, 01:44 PM
Hi Sir,
It is a very Low Milli Amp Draw.
It should not affect your battery too much.
Feel free to contact me with any questions at 210-420-0132
Best,
Mike Benson
TST
04-26-2018, 01:45 PM
sounds great!
Thanks,
Mike Benson
TST TPMS
210-420-0132
04-26-2018, 01:46 PM
That will work.
Thanks,
Mike Benson
TST TPMS
210-420-0132
04-26-2018, 01:47 PM
Very Nice!
Best
Mike Benson
TST TPMS
210-420-0132
QUOTE=Scubanut;1793707]My batteries are still in storage but I keep my repeater inside the battery box. I put a little toggle switch on battery box with light and just flick it on when I connect and off when I disconnect trailer. Attachment 169604Attachment 169605Attachment 169606[/QUOTE]
04-26-2018, 01:57 PM
I mounted my repeater on top of my propane tank cover. I run the wire with a 4 wire flat trailer plug behind the tank cover to the battery. The opposite end is attached to the battery terminals with alligator clamps. Makes it easy to connect and disconnect the 12v power to the repeater.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
04-26-2018, 09:50 PM
Mike ... I got my TST last summer and it did not come with a repeater. Are you shipping this out to those that didn't have it included?
Luke & Carolyn
2012 Cedar Creek Silverback 35QB4
2013 Sierra 3500HD Duramax CC SRW SB 4x4
Andersen Ultimate Aluminum 2 Gooseneck Mount
04-26-2018, 10:41 PM
I wired mine in to the downside of my battery disconnect. The repeater is mounted to the tongue jack post with wire ties. My logic is that if the light on the repeater is on, my batteries are live. Gives me a quick check when I leave the trailer in storage - don't have power there.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
04-27-2018, 03:52 AM
I put mine inside and tied it to the USB/12v plug next to the bed.
Joe
Current: 2022 Keystone Cougar 26RBS
Past: 2020 Rockwood MiniLite 2205S
Past: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
04-27-2018, 06:51 AM
TST
Hi Sir,
We just started including the repeater with kits, and the price of the kits increased now that they are included.
I will make an exception for you, and send you one at no charge. You will need to contact TST at 770-889-9102 ask for Stephanie, I will ask you to pay for the shipping $6.95
Thanks,
Mike Benson
TST TPMS
210-420-0132
04-27-2018, 10:37 AM
THANK YOU MIKE!
Very much appreciated!
Hi Sir,
Thanks,
Mike Benson
TST TPMS
210-420-0132
Luke & Carolyn
04-28-2018, 06:35 AM
I have had my 507 for so long I can’t remember when I brought it. I have always mounted my monitor as high on the windshield as I could place it and didn’t feel like I needed the repeater. My old monitor use to drop a sensor occasionally but the new color monitor doesn’t ever drop a sensor. The monochrome monitor keeps the tires on the screen all the time, just not the temperature and pressure on each tire when the monitor is away from the camper. I like the new color monitor one reason because it drops the tires when the monitor is away from the camper. It’s nice to look at the monitor and just see the truck tires. For new people that buy the new color monitor the psi being on the right will never be a problem for them, I’m slowly getting use to the psi and temperature being on opposite sides
04-28-2018, 07:33 AM
Mine is mounted inside the gas bottle compartment of my v-nose wired to the battery via a switch.
