Old 03-06-2012, 08:44 PM   #11
bsmall's Avatar
Here is what I carry and use.
Bill
2008 GMC Duramx-2500HD 4x4 CrewCab
52 Gallon Titan Fuel Tank
Reese18K Signature Series 5th Wheel Hitch With Slider #30085
2010 Wildcat 28RKBS (West Coast Model)
bsmall is offline   Reply With Quote
Old 03-06-2012, 09:03 PM   #12
sherdep's Avatar
The Viair kit above will do the trick as well.
I have a Viair 420C compressor and a 5 gallon tank mounted to my Frame of my truck so I have air any time I want and it does not take up any more room in the camper.
I also have a set of train horns so if any one gets in my way I give them a blast which is kinda funny cause I usually see them jump in the seat.
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 03-06-2012, 09:53 PM   #13
acadianbob's Avatar
IMO you will be disappointed with that model. If you have any kind of fill to do at all, it will take forever. I'd go with at least a 2 gallon and preferably a 4 gallon. You can get a good one for less than $200. CFM is important once your intitial pressure is gone; or you'll have a long wait to fill. You may find other uses besides your tires; like a compressed air "blower" to clean out radiators, lawn mower, etc. You need CFM to do these things.
Puma Oil-Free Twin Tank Air Compressor ó 2-Gallon, 1 HP, 2.2 CFM, Model# LA5721 | Single Stage Electric Air Compressors | Northern Tool + Equipment
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 03-06-2012, 10:11 PM   #14
bsmall's Avatar
My Bad!
Bill
Old 03-06-2012, 10:30 PM   #15
sherdep's Avatar
Originally Posted by bsmall View Post
I wasn't to concerned about time. If I am out in them middle of nowhere and I need air, 5 minutes won't bother me. I was not wanting to carry anything large and heavy.
I have a larger compressor for the garage, I thought he was looking for something to take out on the road, My Bad..
I think he was looking for a compressor to just fill tires on TV and trailer - thats what I got out of his initial post as well
Old 03-06-2012, 10:37 PM   #16
acadianbob's Avatar
Ok. I saw garage not middle of nowhere. I have a 12 volt I carry along for middle of nowhere.
Old 03-06-2012, 10:45 PM   #17
fast murray's Avatar
I carry a small bostich compressor that was part of a kit that came with 2 nailers. It's light and relatively compact and made me feel way better than carrying an airtank. Stopped at a gas station once with a low tire and put in 75 cents for their air and it didn't run. I unplugged their POS and plugged in my bostich. Didn't take any time to air up the trailer tire.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 03-06-2012, 10:53 PM   #18
caper's Avatar
I would go with a larger tank. As stated the small tank will not be enough air to fill the TV tires.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-07-2012, 05:08 AM   #19
Get a compressor your wife will be able to get rid of at at yard sale with the other toys when you pass.
Chicken Legs is offline   Reply With Quote
Old 03-07-2012, 06:04 AM   #20
Pirate Todd and Wench
If your just topping off tires, any pancake compressor will do just fine. Even when a tire is really low its probably not going to take more than a 1/2 cf of 55psi air.
BUT!
I started looking for the same thing years ago and came across a twin stage 30 gallon unit for around $300 I think it was. Its in the closed attic of my garage with a regulator on the wall down stairs. Since then I have a 1/2 impact with all the sockets, a 3/8 air ratchet, blow guns, inflator, paint spray gun, etc. I haven't picked up a lug wrench in years and I can rotate the tires on my truck in 15 minutes! It really pays for itself, and as I seem to be getting older for some reason it really saves the back! lol
For the road I have a little piece of crap 12v with a 20' extension wire and a plug hit for nails etc. Works great in a jam.
-Todd and Sherri
-2006 F250 Super Duty King ranch Diesel
-2012 Windjammer 3008w
-Equilzer 1200lb hitch
mrtodds is offline   Reply With Quote
