Old 05-17-2016, 07:36 PM   #1
which axles do I have and how to repack?
Hi. I did some searching but must not be hitting the right combo of words.
I have a 2007 Surveyor 255RS. I'd like to understand how to repack my bearings. The brochure says I have Superlube hubs but my search came up empty. Is Superlube the same as Ultra-lube?
Sorry if these are dumb questions. Like I said, I'm trying to understand which type of axles I have and how to go about repacking the bearings.
Thanks in advance.
2008 Surveyor 255RS
2007 Tundra Ltd 4x4 5.7L Double Cab w/ Tow Package
Blue Ox SwayPro
capebuff is offline   Reply With Quote
Old 05-17-2016, 07:55 PM   #2
dieselguy's Avatar
Being an 07, you might still have the paper tags stuck on the axles ... you may have to look for the info stamped into the axle tube. Amongst the info on either there will be a D58 or D60 or D70. These numbers stand for 5800# / 6000# / 7000# axles. All bearing re-packs play out about the same save the never lube axles. Jack up an axle (I won't get in to the placement of the jack) and remove the wheel and tire, Pop off the dust cover and remove the cotter key, spindle nut , and washer. Work the wheel hub a bit and remove the front bearing. Slide the entire wheel hub from the spindle. Remove the rear grease seal and the bearing. Clean both bearings in say solvent and dry, then repack by hand or with a bearing packer (well worth the money). Clean up the bearing cavity in the hub and put the rear bearing back in followed by a new seal (lip faces towards the inside). Look over your brakes and clean them as well as the backing plate. Reinstall the wheel hub, front bearing, washer, and nut. Wrist tighten the nut while spinning the hub and install the cotter key and dust cover. Put the tire back on, lower to ground, and tighten lug nuts ... go for the other 3. I left out some odds and ends, but you get the picture. Google trailer wheel bearing repack for more info.
dieselguy is offline   Reply With Quote
axle
