Old 05-13-2012, 06:15 PM   #1
KRS
KRS's Avatar
Which bearing style do I have? Need to service
Good afternoon all,
Need to pack the bearings. It will be my first time.
The trailer is:
2004 Forest River Wildcat 29BHS
How do I know what type I have so I can refer to the right thread? I've found several threads on this forum, but they have different bearing styles.
The tandem axle trailer has a chrome hub cap that doesn't come off, however there is a black hard plastic plug on the end. I pried one off, and there is a standard looking bearing dust cap (metal) inside. There looks to be almost no clearance to get water pump pliers on the metal dust cap.
I have hoping to have the kind that has a zerk fitting and the old grease comes out around the fitting.
Not sure what else to tell you about them to help identify.
KRS
15.0 BTU ducted roof air
Tow vehicle: 2006 Dodge 3500 cummins turbo auto
Cummins exhaust brake
Air bags
KRS is offline   Reply With Quote
Old 05-13-2012, 06:18 PM   #2
MtnGuy's Avatar
Pictures are always good.
Old 05-13-2012, 06:39 PM   #3
KRS
KRS's Avatar
Here they are !
I don't have a way to resize, so I set my camera on the smallest pic option.
KRS
ID:	13730   Click image for larger version
ID:	13731   Click image for larger version
Air bags
Old 05-13-2012, 06:56 PM   #4
Remove the wheel to remove the cap. Wayne
wayne anthony is offline   Reply With Quote
Old 05-13-2012, 07:31 PM   #5
KRS
KRS's Avatar
Went back out and I figured that's how the chrome cap comes off.
Air bags
Old 05-13-2012, 10:05 PM   #6
KRS
KRS's Avatar
If I remove the wheel, any idea if this is the style with the zerks or is it the type that is hand-packed?
KRS
Air bags
Old 05-13-2012, 10:10 PM   #7
It sounds like you have regular hand-packed bearings, and unless you know what you are doing, I would take it to a shop to get done.
talladega1 is offline   Reply With Quote
Old 05-13-2012, 11:02 PM   #8
With a standard steel cap on the hub, you most likely do not have a zerk. The ones with zerks do not normally have steel caps but are under a rubber plug.
Old 05-25-2012, 01:57 AM   #9
Too old to be too smart
SpringerPop's Avatar
Given what's at stake here, I believe this is very good advice!
Pop
2005 Terry 250RKS, perfect for the two of us and the pups.
It recently replaced our Flagstaff 21FB (which we still have)
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
SpringerPop is offline   Reply With Quote
