Old 07-21-2016, 02:36 PM   #1
Why PERMATEX Red on Bearing Seals?
In the Dexter axle book, on P55, they mention using PERMATEX red on the seals on the EZ lube axles. I have never run across this requirement for packing wheel bearings. Does anyone know why? Is it to prevent leakage between the seal and the spindle if one is using the EZ lube injection?
I have a 2015 Rockwood Roo 23IKSS.
mlawler506 is offline   Reply With Quote
Old 07-21-2016, 02:59 PM   #2
clr
The permatex is applied to the outer surface of the grease seal that contacts the hub of the trailer. This is done so that there is additional resistance to the seal being blown out when you apply the grease to the wheel. PS ensure that you jack up the trailer and slowly rotate the tire while you hand pump the grease. This is per the instructions if you do not you blow out the seal. Not rotating the tire while pumping grease is a good way to have a blow out, ask me how I know.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 07-21-2016, 03:05 PM   #3
Thank you Chuck. Does the PERNATEX go on the I.D. of the seal or does it go along the entire back of the seal that butts up to the backing plate on the spindle?
Old 07-21-2016, 03:34 PM   #4
PhoneDude 8289's Avatar
I apply it to the metal OD of the seal
Lifted 2014 8289WS Diamond pkg
2014 Ram 2500 4wd SB DC TCD
PhoneDude 8289 is offline   Reply With Quote
Old 07-21-2016, 04:19 PM   #5
SilhouettePenny's Avatar
Applied to the OD metal surface of the seal that contacts the ID of the hub/drum. The seal does not contact the backing plate if installed flush with the drum surface.
2017 F350 Dually 6.7 Diesel
2014 Silhouette 299 RKDS
Nights Camped 2016 - 43
He who dies with the most tools, wins!
SilhouettePenny is offline   Reply With Quote
