Old 09-13-2016, 03:58 AM   #91
Witch Doctor's Avatar
Tireman9, how could you set loads by temp. I never heard of that, scratching my head on that one.....
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 09-13-2016, 05:56 AM   #92
Iwannacamp's Avatar
Originally Posted by Tireman9 View Post
Pressure is MUCH more important than temperature. You will not get near dangerous level of temperature without previously getting to significantly dangerous low levels of pressure.
Knowing that pressure changes about 2% for a 10F change shows the numerical relationship.
I wish TPMS didn't report temperature as some are claiming they use temperature to set tire load.
I have run both types and found the external lower overall cost when factoring in the need to pay for dismount & mount & balance when you need new batteries with internal
Good deal. Thank you for the response.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Days camped 2016 8 2017 1
Iwannacamp is online now   Reply With Quote
Old 09-13-2016, 09:09 AM   #93
GreenImp's Avatar
Send a message via MSN to GreenImp
My assumption is that the TPMS temperatures are there to warn you of elevated temperatures due to failed axle bearings or brakes. Or for those that do, heat created by overloading or excessive speed.
I have never heard of that either, but I don't doubt there are people out there who have tried it. I have heard of people adjusting their pressures due to ambient temperature changes though (e.g. summer vs winter)...maybe there's some confusion there.
Yes, I think for cost and (battery access) convenience, external wins. For appearance, anti-theft, and potentially higher accuracy with temps, internal wins.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is online now   Reply With Quote
Old 09-13-2016, 10:40 AM   #94
Commercial Member
Read a post where one guy was trying to "balance" pressure to get identical temperature readings.
I write a blog on RV tire application and safety and give seminars on tires at RV events across the US. 40 years experience as tire design & quality engineer for major tire mfg. Freelander 23QB on Chevy chassis is my RV
RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 10-13-2016, 12:11 PM   #95
hkreck's Avatar
My question isn't about temp. or press. but more about when is the time to replace the tires. I have a 2013 Solera Motorhome 24S. I have had it for 4 years now and have 25000 miles on the it. I've had the tire rotated once in that time and new valve stems put on. I keep the tires covered when not in use and check the pressure on them regularly. The side walls look good and there plenty of thread still on them.
I have heard that they should be replaced after so many years, anyone give me an idea of the standard on replacement?
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 10-13-2016, 12:19 PM   #96
Iwannacamp's Avatar
IMO on LT tires I wouldn't be concerned of age until 8-10 years, but I feel that has a lot to with how the tires are loaded. Max load equals more flex/pressure, heat etc.
2017 Puma 297RLSS
Old 10-13-2016, 12:27 PM   #97
Left Coast
Lt's are different than St's.......St's 4 years if a lot of miles and heat/cool cycles
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
bob caldwell is online now   Reply With Quote
Old 10-15-2016, 09:31 PM   #98
Commercial Member
Motorhomes are different than trailers. Due to unique tire loading (side forces) the life of tires on towables is shorter and many feel 3 to 4 years is a reasonable life and much longer is pushing the limit of having a potential failure.
For motorhomes 6 to 8 seems reasonable with 10 being an absolute max.
There are however no guarantees.
RV Tire Safety Blog
Old 01-31-2017, 05:02 PM   #99
I have read your many post's with interest. One question I have is how do you know/check what PSI your wheels are rated for ?
offduty11 is offline   Reply With Quote
Old 01-31-2017, 05:44 PM   #100
northstar1960's Avatar
Wheels are rated by weight not psi , lots of wheels have that weight stamped on the inside of the rim .
northstar1960 is offline   Reply With Quote
tire, tires
