Old 07-20-2018, 08:21 PM   #121
J_KHawthorne's Avatar
Cold tread sparation.
Haven't posted in ages due to health issues. Good to be back!
In late 2015, I experienced a tire tread separation. I was running load range E Gladiators on my crusader @ 80 psi cold. I use the TST TM-507RV TPMS. There was no pressure or temperature warning prior to the failure. The separated tread managed to inflict $1,700 damage.
The sensor finally reported an alarm when the pressure fell below 70 psi; some 50 minutes after I had mounted my spare and the damaged tire was laying in the bed of my tow vehicle.
I worked with the distributor (API) and was fully reimbursed the full purchase price for all 4 Gladiator tires, as I didn't trust the remaining 3 after this issue. I now run "E" range Maxxis. No issues.
Name:	Tread separation01.jpg
ID:	180543   Click image for larger version
Name:	Tread separation02.jpg
ID:	180544   Click image for larger version
Name:	Tread separation03.jpg
Jim & Kathy
2012 Crusader 290RLT TE, TrailAir flex pin: 2012 Toyota Tundra 5.7 SR5 Dbl cab 4X2 Tow, 4.30 gears, RideRite air, TRD cold-air induction & dual exhaust: Reese 16K Slider: TST tpms
Miles towed to date: 26,890; Nights camped; lost count!
J_KHawthorne is offline   Reply With Quote
Old 07-21-2018, 11:12 AM   #122
Commercial Member
Sorry to hear about your tire problems. We need to remember that a TPMS is designed to do one thing. Provide a warning to the driver of a LOSS ov voltage. Belt separations in themselves do not always result in any pressure loss. From your description I would say your TPMS worked as designed.
Owners of vehicles with smaller tires can perform a quick inspection by following the information in the video in THIS blog post. This is about the only way individuals can learn of an impending belt separation without having an X-Ray machine available or other similar tire inspection equipment.
I suggest that tires be inspected at least annually or before any long trips of 1,000 miles or more or as soon as they get home after any trip of 2,000 miles or more.
.Write a blog on RV tire application RV Tire Safety. 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Perry, GA and Minot ND in 2019
Tireman9 is offline   Reply With Quote
Old 07-24-2018, 02:38 PM   #123
FoxMan
My first blowout was a side wall failure and the last one, on our way home from Fl this spring, was tread separation. I have Truck System Technologies temperature and pressure sensors on all wheels. I run the tires between 78 and 80psi. The last blowout was just after I fueled up and got back on 81 about 5 miles and it let go.
altfox is offline   Reply With Quote
tire, tires
