Old 09-04-2016, 10:18 PM   #71
Airdale's Avatar
[QUOTE=Sailor Bill;1308989]Quick question, from the dealer / Manufacturer the tires are filled with nitrogen, what are you supposed to do when the tire is 5 lb. low, use air from a local gas station. Did a search and so far haven't found an answer.
Thanks in advance.[/QUOT
If your talking about your RV trailer manufacturer and relying on service stations for inflation pressures you're way behind the "8" ball.
Air is 78/79% nitrogen. One is nearly as good as the other for trailer tire servicing.
USN - RET - PDRL
DOD - RET - Journeyman Aircraft Mechanic
SSA - RET
Airdale is offline   Reply With Quote
Old 09-04-2016, 11:10 PM   #72
Blackhat6mike's Avatar
Send a message via Skype™ to Blackhat6mike
It is very easy to walk around your unit with your cell phone and record pictures of the data on all your tires. It only takes a few minutes and you will have a record of each tire.
A reminder, once again, a TPMS is worth it's weight in gold. I just don't understand why everyone doesn't have one. REAL TIME INFO on whats going on.
2013 Silverado 2500 HD Duramax/Allison Tuned
Aviator Wright Flyer #1919
"First In, Last Out". 11B4Y
DAV, MOPH, VFW, 5/7 Cav,1/8 Cav Assoc.
11th ABN Pathfinder Co. N7MIP
Blackhat6mike is offline   Reply With Quote
Old 09-09-2016, 12:06 PM   #73
Crookedread
crookedread's Avatar
I have been concerned about tires also so run under 65 mph, check tire pressure constantly, and weigh my trailer when heading out on a trip. I also bought a Ryobi temperature gun so I could check tire temperatures. After taking the temperatures the first time, I had to laugh at myself because I had no idea what was acceptable. At about 7000 pounds on a 100 degree day, I was at 116 degrees for all four tires. With two quads and no water I weighed 7300 with a weight bias more towards the rear, my front axle tires were 116 and my rear axle tires were 121. Is this an acceptable temperature or will I soon be sharing my blowout story? By the way, I have marathon D range tires at 65 psi.
Crookedread
2016 Duramax
2011 Stealth 2312
crookedread is offline   Reply With Quote
Old 09-09-2016, 12:25 PM   #74
Send a message via AIM to terryallan
curbing
Tire especially trailer tires also fail from curbing / running over, or brushing against curbs. That damages the side wall. But mostly trailer tires fail because of age.
Terry and Shay
Lazy Campers
FootHills NC
terryallan is offline   Reply With Quote
Old 09-09-2016, 12:51 PM   #75
Usually Confused Member
emm-dee's Avatar
Crookedread
2016 Duramax
2011 Stealth 2312
I get similar results. With the Harley loaded my tongue weight reduces about 100 pounds. Rear tires are usually 5-7 degrees hotter than front. With Harley not on board the front tires run about 5 degrees warmer.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 09-09-2016, 01:03 PM   #76
Crookedread
What kind of temperatures do you see and what does the Harley weigh?
Crookedread
2016 Duramax
2011 Stealth 2312
Old 09-09-2016, 04:42 PM   #77
emm-dee's Avatar
Crookedread
2016 Duramax
2011 Stealth 2312
Highest I've seen is 135. That was after two hours nonstop on an Interstate at 60-65 mph and air temperature in the 98 degree area. The non-sun side of the TT WAS 10 degrees cooler.
The Harley (Road Glide Ultra) comes in at about 940 pounds with full fuel. The front wheel is chocked between the trailer axles. I'm still looking for the right size water tank to install under the aft frame so when the bike is not loaded I can put 400 pounds of ballast weight back there. The TT seems to handle just a little better when loaded with the Harley. CAT scale weight is 7,800 pounds (out of a max of 9,800 pounds).
Old 09-09-2016, 05:38 PM   #78
Crookedread
Thanks, that really helps. I'm going to try and move quads closer to the front as I am always looking to keep things balanced. I can go sideways a little but will have to see what it does to my side to side balance.
Still trying to get my wife on board with a Harley so we could use it for touring on our trips. The outlook looks a little bleak right this minute but you never know!!
My fuel tank is in the back of the trailer so I fill it sometimes and it does ride smoother when I don't have the quads. I think it is 34 gallons. The water tank is 100 gallons and it makes a significant difference when towing in a lot of cross wind.
I hope more RV'ers will supply us with their tire temperatures.
Thanks again
Crookedread
2016 Duramax
2011 Stealth 2312
Old 09-10-2016, 05:54 AM   #79
Witch Doctor's Avatar
Crookedread
2016 Duramax
2011 Stealth 2312
Did you also shoot your TV tires? Shooting the tire is a help, but remember that is the outside rubber temp not the internal temp. Blow out occurs in the the temp area of 150 degrees or so measured inside the tire. If it was a 100 degree day and you were only getting 116 /121 I would say you running pretty cool. I used to use the temp gun always if I was within 5 to 10 degrees of my TV temp I thought I was really alright. The gun is good to shoot your hubs it can tell you if a brake drum is dragging, which cause extra heat to build in the tire. I know that my TST temp is set at 150 degrees that is what they recommend. I normally see anywhere from 96 to the highest I think was 107. So I would say that you are fine to me. I'm going to have to try and shoot my tire and compare it to the internal temp reading. I would bet that the sidewall shot with the gun will be higher. If I remember right TST says that blow out are most common with an internal temp of 150 to 175 degrees. I don't know if that helps you, but for a 100 degree day that pretty cool to me, but I'm no tire expert at all.... Also shoot the asphalt being that also will contribute to the tire temp. I didn't read do you also have TPMS on your TT if not it is really the best investment that you can make...I also asked what was acceptable and no one could give me an answer... after I blew a hole in the side wall of the org. tires after 6000 miles I switched to Marathon "D" range from the trail express "C", ran those for 3 years trouble free then a belt separated, so again I bought new tires this time Maxxis 8008 "D" so far so good. Really I'm getting tired of buying tires in four years two sets, but it still cheaper then the damage that happens from a tire failure.
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 09-10-2016, 09:54 AM   #80
GreenImp's Avatar
Send a message via MSN to GreenImp
I recently tested tire temps covered vs uncovered while in storage and measured 122 uncovered in direct sunlight (infrared surface temp reading). The internal temp of the same tire was 86 according to the TPMS. This was without the trailer having been moved/towed at all, after about 3-4 hours of direct sunlight, and the ambient temp was 66.
I'd say your temps are perfectly fine.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
tire, tires
