Old 09-10-2016, 10:43 PM   #81
Crookedread
crookedread's Avatar
Witch Doctor, I did shoot my tv tires and they were cooler on the rear, about 100 degrees. Interesting that the fronts were about 110. I know that the diesel weight made the front heavier than the rear so thought that was ok. Shot the bearings and brakes but low numbers so I don't even remember what they were. New gun so I shot my wife's neck and she said "back in the truck Bucko!" So no other temps!!
Feeling better until I just read Tireman9's discussion about accumulative damage to tires. A little over weight, some speeding, couple of curbs, side loading from wind.
I'm taking a trip to the Dakota's next week but I think it is going to be on new tires to try and avoid any damage.
Crookedread
2016 Duramax
2011 Stealth 2312
crookedread is offline   Reply With Quote
Old 09-10-2016, 10:48 PM   #82
Crookedread
Thanks Greenimp! Interesting temperatures. I'm going to look into a tire pressure system. I've been putting it off but think it's a good investment!! Got any ideas on a good brand??
Crookedread
2016 Duramax
2011 Stealth 2312
Old 09-11-2016, 09:21 PM   #83
I have had the TST system for about 4 years now, saved us twice, (First time paid for itself.) It shows no more than 110 on hot days on the road. Un sunny side is 5 to 10 degrees lower .
Dale & Karen
2015 Lacrosse 311RLS
2006 F-250 The 06-6.0
Dwilcox is online now   Reply With Quote
Old 09-12-2016, 12:37 AM   #84
Crookedread
Thanks Dwilcox!!
Crookedread
2016 Duramax
2011 Stealth 2312
Old 09-12-2016, 12:48 AM   #85
Commercial Member
I bought system with Lifetime warranty and rapid leak early warning. Also can check pressure in AM without having to use hand gauge (takes abt 15 min to get a fresh morning reading.
I write a blog on RV tire application and safety. RVTireSafety.com
Also give seminars on tires at RV events across the US. 40 years experience as tire design & quality engineer for major tire mfg. Freelander 23QB on Chevy chassis is my RV
Tireman9 is offline   Reply With Quote
Old 09-12-2016, 08:06 AM   #86
Iwannacamp's Avatar
I think I have decided on the TST 507. Should I get regular or flow through or hold out for internal sensors?
Our new 5er 10-26-16
Days camped 2016 8
Old 09-12-2016, 11:12 AM   #87
GreenImp's Avatar
Send a message via MSN to GreenImp
I chose the standard sensors as it was important to me that they be as shallow as possible as to not stick out of the rim (less weight is better too). It does not bother me to have to remove the sensors the once or twice a year I need to add air. I would almost certainly have gone for internal if they had been available at the time I purchased.
Looking at TST's website, it appears that the internal are currently in stock and shipping....hmmm.
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 09-12-2016, 11:19 AM   #88
Iwannacamp's Avatar
I figure the internal would do a better job of temperature management... I guess the pressure is the most important input. I dunno.
Days camped 2016 8
Old 09-12-2016, 11:22 AM   #89
GreenImp's Avatar
The TST 507 is a great choice, but there are other great options as well. My only complaint with the TST system is the external antenna design of the receiver. Not only does it look bad when compared to the clean look of an internal antenna, but my then 3 or 4 year old son broke it off within seconds of me taking it out of the package (obviously not TST's fault). Luckily I repair electronics daily and it was no issue for me to repair the circuit board where the antenna connector mounts.
Old 09-12-2016, 08:13 PM   #90
Commercial Member
Pressure is MUCH more important than temperature. You will not get near dangerous level of temperature without previously getting to significantly dangerous low levels of pressure.
Knowing that pressure changes about 2% for a 10F change shows the numerical relationship.
I wish TPMS didn't report temperature as some are claiming they use temperature to set tire load.
I have run both types and found the external lower overall cost when factoring in the need to pay for dismount & mount & balance when you need new batteries with internal
tire, tires
