Old 05-19-2016, 10:16 AM   #1
Commercial Member
Why tires fail ?
Tires fail from two basic causes.
Low air pressure
and/or
Long term degradation of the rubber usually from excess heat.
Low pressure (active leak from puncture or loose valve stem or valve core are most common reasons) can lead to a Sidewall Flex failure or more commonly called a "Blowout". The sidewall cord can melt (polyester) or fatigue (steel). Many TT owners fail to realize that they will never "feel" the results of a tire loosing air till it is too late and they are surprised when the sidewall lets go. The rapid air loss "bang" even when the tire only has about 10 to 20 psi in it, is a big surprise IF they even hear it. HERE is a post on how to know if you have a run low flex failure. A TPMS can provide warning of air loss so is good insurance and can easily pay for itself.
The long term degradation of the rubber at the edges of the belts can lead to a belt and/or tread separation. Even if the tire keeps its air you can have this type of failure so a TPMS will not provide a warning. This degradation comes with age as rubber is always loosing flexibility. Just think of those rubber bands you found in the back of the desk drawer. Even in cool and dark they got brittle. HOWEVER running at or near or above the load capacity of a tire will result in increased heat generation. Increased heat actually can accelerate the aging process with a doubling of the rate each increase on 18F. Running a margin of at least 15% between capacity and measured load is a good first step. Running at higher speed will also generate excess heat.
Realizing that over half of the RVs on the road have one or more tire in overload is one main contributor to the high tire failure rate. Simply thinking that a tire will fail because the tire plant building is painted blue rather than green is not logical.
Buying the lowest cost "no-name" tires is IMO a major contributor to poor results. If the main objective is the lowest cost tire why would anyone be surprised with short tire life.
Just paying more however is no guarantee of better quality. I believe the best tool available is comparing Warranty and service support.
Can you get multi year warranty on the tires? Is it possible to get Road Hazard coverage? Is there a nationwide network of dealers who stock the brand you are considering?
.Write a blog on RV tire application RV Tire Safety. 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Perry, GA and Minot ND in 2019
Tireman9 is offline   Reply With Quote
Old 05-19-2016, 10:20 AM   #2
Iwannacamp's Avatar
Excellent information.
In case you have never said.... What is your No.1 choice for 15" branded tires? I know 16" changes the parameters, so I asked about 15".
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Old 05-19-2016, 03:10 PM   #3
Commercial Member
Sorry, can't provide a brand name as there are too many variables such as dealer support etc. I might find a brand "Q" tire locally from a dealer who offers 3 year 100% coverage for any failure while in another part of the country you find no dealer for that brand who will offer more than a 7 day satisfaction warranty.
I have three posts on my blog with tag "Best tire" You might find them informative
Old 06-06-2016, 10:42 AM   #4
Commercial Member
These are real Run Low Flex failures
It is clear that few people use the search function of this forum when asking questions about tire failure as there have been only two views of this thread in three weeks.
I keep reading " I had a Blowout" when many times the failure is not a blowout simply due to high pressure. In fact I do not ever recall seeing any such failure properly identified on this or any other RV forum.
So I keep posting the same pictures of what a real Run Low Flex Failure looks like as seen below
RLOF is caused by driving on a tire that has lost significant air (more than 50%) for a number of miles.
Old 06-06-2016, 05:16 PM   #5
Witch Doctor's Avatar
That's interesting, I had what I would call blowout on my trail Express I didn't drive over an 1/8th of mile to get on the off ramp and it was shredded. The tires where full of nito and I just so happened to look in the mirror and seen a puff of different color air and pulled off immediately at like 5 t0 10 mph. That tire was shredded...
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-06-2016, 05:24 PM   #6
toslow's Avatar
great info, thanks for posting it
haven a blast
toslow is online now   Reply With Quote
Old 06-06-2016, 05:39 PM   #7
Akrap's Avatar
I had just read about this last week, and was over talking Trailers with my friend. He told me about something he never thought possible. He had blown a tire on his last trip home. It just so happened when he started telling me about it I knew in the first sentence what he was about to say. Well he took me in to the garage and the tire looked just like that. Then we looked at the trailer, and wow it really eat the bottom out of it. Point I am making is thanks for sharing all this great information. I passed on the forums name and told him to start reading up.
If you go with the flow, you miss too much.
Randy Pugh
Cadillac Escalade
Rockwood Roo 21SS
Moses Lake WA.
Akrap is offline   Reply With Quote
Old 06-06-2016, 06:27 PM   #8
Cyber Phrenologist
Radio's Avatar
Putting load range "E" tires on this month. They are rated at 2830 pounds. 4 x 2830 is 11320. Specs say the trailer fully loaded is 8400, but on scales about 7800 the way we travel. So that's 3520 margin. Might ride a little rough, but that's OK.
For what it's worth they will be balanced, too. 80 psi and never over 65, which is hard on the F-150 anyway.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 06-06-2016, 09:46 PM   #9
Commercial Member
OK What was the reading on your TPMS?
Old 06-08-2016, 07:28 AM   #10
Commercial Member
File a failure complaint with NHTSA
Recently read about a failure and asked if the person had bothered to file a complaint with NHTSA, He said it was NHTSA's responsibility to be testing the bad tires. I responded...
NHTSA is under budget constraints thanks to Congress, so they have to prioritize and in general all tires are low on the list of items they try and monitor (air bags, seat belts, child seats and any other "safety related item on motor vehicles).
Due to low failure rates of tires and even lower personal injury rates and further down would be fatality rates of less than 1 in 100,000 or fewer complaints.
NHTSA also knows from previous and ongoing data collection that over half of RV owners have one or more tire in overload with most of those due to poor maintenance and low air pressure.
Another issue is that if they only have a few actionable complaints on file how can they justify spending $$ on testing that specific tire. Which one brand and design and size would you advocate spending $30 to $100 thousand on for the battery of tests and how could they justify that expenditure in front of Congressional hearing asking why NHTSA wants a bigger budget?
A couple years ago I some time researching and reviewing complaints on file that might have been from RV owners.
What I found were a lot of "sob stories" but very few facts. Less than half had a proper size i.e. "My 205-15 tire failed".. A smaller percentage had the complete DOT serial. Some said things like "My Firestone Marathon tire exploded while on our trip to visit my mother who was sick". Sorry but trip information is on no value and if the complainant can't be bothered to know the brand and design of the tire how can they trust the rest of the information.
Complaints do not need to be long but they really need one thing it's the COMPLETE DOT serial including date code at end. I have advocated that people collect and write down this information before there is a tire problem and keep that info with the rest of your important RV documents. The DOT serial is also used if/when there is a recall so you would need to know the serial to know if your tires are subject to recall. Yes there have been recalls that involve tires that are on RVs.
I do understand that people want to get back on the road but at a minimum would be to capture a couple pictures of the failed tire (tire filling entire frame is best). NHTSA may or may not ask for the pictures in follow up but if you don't even have a couple of pictures exactly what evidence are tou bringing to the table?
You should also try and carry a trash bag large enough to carry the failed tire back to the dealer if you don't have spare tire rack. In reality the dealer is suppose to file a complaint with his distributor so that information can be sent on to NHTSA but sometimes I wonder if they bother so it really is up to us, the users to file the complaint.
tire, tires
