Old 10-29-2016, 09:29 AM   #1
Windjammer/V-Lite Lift Kit!
I noticed this Trailer that is the Same as ours,But it was sitting WAY UP! I had to ask the owner and they are the Orig owners and the Factory had a "Recall" they put the "Lift Kit" on it,nothing else! I took Pics of the spacers and the "Stack Height" is the same as ours,BUT their "Down Angle" was totally different angle than ours,thus the "Height above the Tires"! Youroo!!
ID:	124121   Click image for larger version
ID:	124122   Click image for larger version
Old 10-29-2016, 09:38 AM   #2
Dexter makes that kit, the one that will give you about 3" or a little less, but it sounds like you ruled out they used that. The only way I know of to get a different down angle on a torsion axle is to order/spec the axle that way. If you look at all the tech BS over at Dexters page there are many different combinations for every size axle. I believe its called "start angle".
They probably installed different axles.
Mr Havercamp is offline   Reply With Quote
lift, v-lite, windjammer
