Old 06-16-2019, 01:11 PM   #1
69BBC's Avatar
Wiring into hub brakes
Was checking underneath for road damage and spotted a wire hanging. Where 3 wires are joined into some sort of connector, one was pulled out. I can not figure out how to open this connector to see how the wires are mated. Anybody ever opened one of these ??? Thanks Larry
2015 Sabre 321RSKS
Ford 6.7 SuperDuty
69BBC is online now   Reply With Quote
Old 06-16-2019, 01:43 PM   #2
Usually one time use, but I have pried the top off, pulled the metal cutters back up to reuse in an emergency road repair, but replaced once home.
wvram is offline   Reply With Quote
Old 06-16-2019, 01:54 PM   #3
Never seen a connector like that one. If they connected the brake wire from the TV to each wheel's hot brake wire, you'd have 3 wires, so it makes some sense.
Same for the ground if they tied the two wheel's ground wires to a 3rd that ran to ground somewhere. However, on my Roo, the two grounds had ring connectors which both went to a single screw onto the frame, there wasn't a separate ground wire back to the 7-pin. I haven't really checked out my Mini Lite, but I'd guess it's the same.
If you're handy, you could always solder the 3 wires together.
Something like this might do the job for you:
https://www.homedepot.com/p/Ideal-33...333S/202911030
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 06-16-2019, 02:16 PM   #4
69BBC's Avatar
Plan to replace them with better connectors. How did you get it separated ???
Just rip the white part up or does it separate from the middle portion .
thanks Larry
2015 Sabre 321RSKS
Ford 6.7 SuperDuty
Old 06-16-2019, 02:32 PM   #5
Was able to pry what looks bluish in your pic.
https://www.amazon.com/gp/aw/d/B07F9...?ie=UTF8&psc=1
Hope this pic helps
Old 06-16-2019, 02:56 PM   #6
Here's a better pic and one to scroll thru.
https://www.amazon.com/Wire-Connecto...W6AKRRBBPD8R60
Old 06-16-2019, 03:06 PM   #7
69BBC's Avatar
thanks wvram,
will try to source some locally and open the old one in the morning. Off for a frosty beverage.
2015 Sabre 321RSKS
Ford 6.7 SuperDuty
Old 06-17-2019, 12:41 PM   #8
Lins's Avatar
I had to cut out those connectors when I replaced the brake magnets. They will come apart if you're lucky, but I'm pretty sure they're intended as a one-time use.
2007 Rockwood 2701SS
2014 Triumph Bonneville. NH Togas, TTP Tune 3
1953 GMC 9314
Lins is online now   Reply With Quote
Old 06-17-2019, 12:58 PM   #9
Solder and use marine type heat shrink. Just fixed mine!
davidgle is offline   Reply With Quote
brakes, wiring
