Old 01-14-2016, 03:23 PM   #1
Question Yet another tire question
The Clipper 17FQ came with 13" D rated Westlake tires and I just do not feel that a 13" tire is adequate, just looks to small for the job. I have flipped the axle the get more clearance so that I can now use a 14" or even a 205/15 without concern of bottoming out.
After HOURS and HOURS of reading and research I finally decided on the Kumho 205R14C or the Maxxis 205/75R-15 both are both are D rated tires (have to buy rims so that is not an issue as to either 14" or 15"), the problem is neither is available locally without ordering. A 3 to 5 day wait is not an issue sitting at the house BUT what is the availability going to be out on the road should a need for a tire arise?
So there is my question, what have others found for the availability of either brand while traveling? Or is there another brand that I am over looking and should consider? Smaller size tires in D ratings is slim pickins.
John & Mary Jo
Enjoying the adventure
Ky-N is offline   Reply With Quote
Old 01-14-2016, 03:56 PM   #2
RSchleder's Avatar
Interestingly, I just ordered 4 new MAXXIS trailer tires for my 1 year old Wildcat MAXX to replace my oem tires with 5K miles on them. My tires will be here tomorrow. I plan on carrying my spare which will be the original oem tire. If I get a flat tire with the MAXXIS I'll simply put the spare on and head on down the road. I'll get the flat tire repaired at the nearest tire place and replace the spare with the MAXXIS. If I need to replace the MAXXIS due to road hazard/blow out ( which is far less likely with a good quality tire like the MAXXIS), I'll start stopping at tire places to find, or have a tire shipped to the same companies facility at a town/city that I'll be at in the next few days. In my opinion, buying the MAXXIS is a lot less risk than buying the readily available "China Bomb" tires that DO fail at a much higher rate!!!
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 01-14-2016, 04:07 PM   #3
A32Deuce's Avatar
A word of warning on wheel size change. I learned this lesson from experience. Find out f the wheel spindle can handle the larger diameter! Found out just because a bigger diameter rim fits doesn't mean the spindle can handle the extra leverage applied to it. They can bend/brake! Ask before the jump. Just my experience!
A32Deuce is offline   Reply With Quote
Old 01-14-2016, 04:09 PM   #4
Usually Confused Member
emm-dee's Avatar
Not sure about the "chain" tire outlets but the independent dealer I frequent has several different brands in "stock" but says he never has a china bomb in the store. If someone wants them he says he'll order them but puts a statement on the invoice that the tire is not recommended.
He, along with most other dealers, cannot stock every size of every type but can usually get the ones you want from the distributor warehouse by the next day.
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
Old 01-14-2016, 04:14 PM   #5
Just got off the phone with the local Kumho dealer and he said they no long make the 205R14C or any small tire, only semi tires which sounds fishy since TireRack has them listed ready to ship.
My big concern is being stranded and not able to get replacements if the need were to arise like it did last summer in Wyoming when we lost both Goodyear tires. They were fine that morning as I ALWAYS check the tire pressure before hitting the road.
Coach-Net's roadside service payed for itself big time that day!!!
John & Mary Jo
Old 01-14-2016, 04:21 PM   #6
A32Deuce's Avatar
Ky-N see post #3 before any purchase!
Old 01-14-2016, 04:29 PM   #7
Yes, looking into it.
John & Mary Jo
Old 01-14-2016, 04:51 PM   #8
RSchleder's Avatar
If you're really that worried, carry 2 spare MAXXIS tires (or whatever brand you decide) either on or off the rims!!!! The situation you describe should be VERY rare and could occur regardless of which tire you choose. As stated in this thread, dealers do not carry every brand in every size, so standard procedure is for the tire shop to order tires they don't have in stock and receive them the very next day. This was certainly my experience today as I'll be having my MAXXIS tires installed tomorrow @ 10:00AM!
30 years RV'ing
11 different RV's
Old 01-14-2016, 09:54 PM   #9
Blackhat6mike's Avatar
We installed 4 Maxxis M8008 on our TT just before or trip down to the FL Keys. They replaced 4 "new" china bombs [Akuret], two had already popped within less than 2,000 miles.
The drive down and back was so much smoother and no white knuckles. Pressures and temps were all steady. We have three Hercules tires as spares that were already purchased before the Maxxis. If you have to have a china bomb, I believe the Hercules are the best of the worst.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 01-15-2016, 10:29 AM   #10
Originally Posted by Ky-N View Post
.........BUT what is the availability going to be out on the road should a need for a tire arise?..........
I guess it would be wise to carry a spare. I think any brand would work as a spare to at least get you somewhere to wait out a delivery.
phillyg is offline   Reply With Quote
tire
