Old 01-23-2013, 02:16 AM   #1
2003 28' Cardinal
We just recently bought the above rv and noticed a lot of jerking, lurching while towing it home (130 miles). I'm looking to install a glide type hitch but not sure what to get. Any help? Delco, Moryde, Reese, etc.
Kapsie58 is offline   Reply With Quote
Old 01-23-2013, 04:17 AM   #2
cardinal4fun's Avatar
What you have experianced was called "chucking", thats when the camper and the truck are seeming to be going to the same place but in different times. To stop that or reduce it you will need a different style pin box other than the standard one that comes with Cardinals. I put a 5th Airbourne on Cardinal and it stops about 90% of the chucking.
The hitch will not make a difference unless you get a very expensive air ride type hitch. You did not say what size truck you have, but I would first look into changing over the pin box.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 01-23-2013, 09:02 AM   #3
Crusader's Avatar
Just yell out "GETTY UP" !!
TV= 2012 F-150 FX4 Supercab
FW= 2011 270ret Crusader
Hitch= Reese Pro Series 16K Hitch
Crusader is offline   Reply With Quote
Old 01-23-2013, 11:07 AM   #4
My truck is 06' Silverado 1 ton dually with duramax. We downsized from a 36' hitchhiker that was just too big for our needs.
That 5th wheel had a demco glide ride that worked great. I was just wondering if anyone had some constructive ideas I.might use,
Old 01-25-2013, 07:36 AM   #5
I think you answered your question. I have a TrailAir.
Tri Glide Air Ride Pin Box
John & Diann
Cooper
2010 - Cardinal 3150
2011 - GMC 3500 Dually
Cardinal RV Club
Travelers is offline   Reply With Quote
Old 02-13-2013, 03:26 PM   #6
I have a 2003 33CKTS Cardinal. Demco Glide Ride Pin Box and Trail Air E-Quaflex between the springs cured the problems.
C.B.
cbvp is offline   Reply With Quote
