Old 09-05-2017, 10:54 AM   #1
2012 3450 RL wheel bearing seals pn#
Does anyone know what the part number is for the wheel bearing seals on my 2013/13 cardinal 3450RL with 7000# axles and 235/80/ R16 tires and stock aluminum 8 lug rims? I can cross reference just about any part number...thanks...Lee
LCWarden is offline   Reply With Quote
Old 09-07-2017, 09:03 AM   #2
If you know which axle's are on your Cardinal, you should be able to go to Dexter's website for that info.
Dave
2017 Cardinal 3850RL Mocha Pearl full body paint
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
djousma is offline   Reply With Quote
Old 09-13-2017, 07:32 PM   #3
Dexter part # Fits Dexter 12 x 2" hub, 2.250 ID x 3.376 OD (after 1998)
010-036-00
Lee & Beth
2013 Cardinal 3450RL
Towing it with a 2014 Ram 3500 SLT cummins 6.7 diesel
Old 09-19-2017, 10:21 AM   #4
My 2012 Cardinal 3675RT has Lippert (LCI) Axles for sure. The LCI tag is on the rear side of the axle tube. I also understand the Dexter axle numbers are stamped in the tube in a similar location.
If you get the axle brand, model, serial no. you can contact eTrailers or most other supply houses and get the proper parts.
2014 Ford F350 CC LB FX4 6.7LPSD 3:55 E-Locker
Bellville, Texas
Austin County "Colonial Capital of Texas"
CMelder is offline   Reply With Quote
2012, seal, wheel
