Old 08-03-2015, 02:19 PM   #1
29RKLE kitchen propane sensor wiring
Hello, new to the fifth wheel world and just purchased a 2007 29RKLE unit. I have a propane sensor in the kitchen area that has only 5VDC at the wiring for the unit. The wiring is a white - and a White/Brown stripe +. There is a 1 amp in line fuse. I am checking voltage upstream of the fuse with the sensor disconnected... Voltage at distro panel is 12VDC
Problem; cannot find the other end of the wiring at the distro panel or at the battery...
Anyone have experience in this and happen to know where the sensor is fed from?
Thank you in advance!
Dan
damabo is offline   Reply With Quote
propane, wiring
« exterior tv | TV »
