Old 10-13-2015, 07:46 AM   #11
fonzie's Avatar
Since you are hook up to a 15 amp circuit and most likely have a 50 amp shore power supply and using adapters, you might only be powering half of your AC distribution panel.....you would need to check with multi-meter at adapter to see if both L1 and L2 have power to neutral......
Fonzie
Old 10-13-2015, 08:10 AM   #12
Canadian Contingent
Dogpatch's Avatar
I checked the breaker panel. All breakers are on. The only thing I haven't checked is the fuses.
I need my glasses for that! LOL
Les and Bonnie with 4 Leggers Bella and Shelby
2010 Cardinal 3450RL 4 slide Full Body Paint pushing our 2015 Ram 3500 Laramie 4x4 CCSB SRW - Pullrite 2900 Superglide 18k
Dogpatch is offline   Reply With Quote
Old 10-13-2015, 08:22 AM   #13
fonzie's Avatar
Breakers can be all on but if you only half power from supply, then half your distribution panel will be out......
Fonzie
Old 10-13-2015, 09:20 PM   #14
Canadian Contingent
Dogpatch's Avatar
EUREKA!!! I found it. It was on the side of the dresser.
Pushed reset and VOILA! Power to the plugs!
Name:	ImageUploadedByForest River Forums1444789237.830684.jpg
Old 10-14-2015, 05:40 AM   #15
Witch Doctor's Avatar
That's great, back in Business. Weird place they put that, but now you know where it's at.
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-14-2015, 07:56 AM   #16
Canadian Contingent
Dogpatch's Avatar
You always worry buying a new to you "Used" anything. You can check all the things you can think of pre-purchase and still get stung.
I've been lucky on this fifth wheel that the only costly thing I've had to do was get the roof and slides resealed and I knew I was going to have to do that and negotiated an excellent purchase price with that in mind.
The only thing mechanically wrong that was found when I had it at my dealer for needed roof reseal was to replace the outside shower tap.
Old 10-14-2015, 08:22 AM   #17
Sometimes IMO it is best to buy used if it's in good condition, let the others have the headaches of working through the new unit problems and they all have them. Even if you bought that in 2010 it would be time for resealing anyway. Good Luck and enjoy your rolling home...
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-23-2015, 04:04 PM   #18
Hobbit
Hobbit's Avatar
We had a similar problem on our Blue Ridge, which I am told is made in the same factory as the Cardinal, and found the GFI reset on the hard-to-find electrical receptacle on the bottom side of the cupboard near the sink. Take a look under your cupboards. We had our unit for a couple of years before we knew there was a plug there.
Hobbit is offline   Reply With Quote
Old 10-28-2015, 08:56 PM   #19
TwoNorthern
Send a message via AIM to TwoNorthern
Take a peek under the upper cabinet next to the stove. We have a 3625 RT and had the same problem. Ours magically disappeared but while trying to locate the GFCI outlet controlling the storage and bathroom and outside, I found a real GFCI receptacle under that upper cabinet. We have a kitchen island and the outlet at the end of that also was affected. Happy searching.
TwoNorthern is offline   Reply With Quote
Old 10-29-2015, 09:06 PM   #20
We have a 3450. Look under the cabinet left of the stove. That works the under belly lights,refrigerator and a few other things. You also have one in the bathroom.
MABradley is offline   Reply With Quote
