Old 10-11-2015, 09:16 AM   #1
Canadian Contingent
Dogpatch's Avatar
3450 RL GFI Reset?
On my 3450 RL, My outside wall plug and inside basement storage plugs aren't working. As well, my rear electric stabilizer jacks won't operate. My front electric jacks work and other interior plugs work. I'm plugged in to 15 amp plugin right now.
The TVs work.
I checked the breakers and all are on.
Is there a GFI plug that has a reset button somewhere? I kinda checked around but the unit is new to me.
Any ideas on both GFI's and Rear electric stabilizer jacks?
Les and Bonnie with 4 Leggers Bella and Shelby
2010 Cardinal 3450RL 4 slide Full Body Paint pushing our 2015 Ram 3500 Laramie 4x4 CCSB SRW - Pullrite 2900 Superglide 18k
Dogpatch is offline   Reply With Quote
Old 10-11-2015, 09:57 AM   #2
garmford's Avatar
Check the outlet in the bathroom.
2012 F350 DRW 6.7 PSD
Blue Ridge 3710 BH
garmford is offline   Reply With Quote
Old 10-11-2015, 10:46 AM   #3
ditto on the bathroom. I have a cardinal and the sockets in the kitchen went out and I finally found the gfci reset in the bathroom
CHICKDOE is offline   Reply With Quote
Old 10-11-2015, 08:57 PM   #4
Canadian Contingent
Dogpatch's Avatar
The GFI in the bathroom says "GFI Outlet" but there is no buttons on it to reset like on a typical GFI plug.
Anyone got any thoughts on why the rear electric jacks don't work from the outside switch?
Old 10-12-2015, 04:08 PM   #5
Our first TT had the GFI recept. in the kitchen. Controlled downstream recepts from there.
James Briar is offline   Reply With Quote
Old 10-12-2015, 09:44 PM   #6
Canadian Contingent
Dogpatch's Avatar
As luck would have it I tapped on the electric motor and the rear stabilizer jacks worked.
I still haven't found the GFI reset. The bathroom doesn't have the reset button. It only has "GFI Receptacle" printed on the center face.
Old 10-12-2015, 09:59 PM   #7
Witch Doctor's Avatar
Your rear motor breaker just reset, they reset by themselves they are auto reset if you overload them going down or bringing them up and holding the button to long. I would check in the galley area probably by the sink. I have two GFI with test buttons one in the head and one in the galley on the sink island most are located in a wet area. You have to have one. could be located at an outlet in the storage area or outside plug.....Keep looking you will find it.
Coachmen M/H
Concord
2018 / 300 DSC
Witch Doctor is online now   Reply With Quote
Old 10-13-2015, 05:28 AM   #8
garmford's Avatar
Do you have washer/dryer prep on your unit? If so there's an outlet there.
Blue Ridge 3710 BH
Old 10-13-2015, 07:34 AM   #9
Canadian Contingent
Dogpatch's Avatar
I thought I looked in there as well.
Old 10-13-2015, 07:44 AM   #10
They also make a GFI breaker, Check your breaker panel. Not sure where they put it by code you have to have one.
Coachmen M/H
Concord
2018 / 300 DSC
