Old 02-17-2012, 10:53 AM   #1
37RL underpanels
My rig has the extra winter insulation package (at least that's what I paid extra for). Has anyone ever removed an under frame sheetmetal panel or two? They're HUGE.
sddmr7 is offline   Reply With Quote
Old 02-17-2012, 11:42 AM   #2
Yes, have removed several, getting to water leaks and other stuff. They are a pain, but basically just bolted on. Nice to have help, and they overlap, just like a Tin roof, so must come off in order, and go back that way. Also they are sealed to the frame with expanding foam, so you will want to have some on hand when you put them back up.
Tip, take a Sharpie marker, and label them, position and draw an arrow to the front.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 02-17-2012, 12:16 PM   #3
Your advice helps take the uncertainty out of it. I like the sharpie idea. Thanks, Steve
