Old 07-23-2012, 01:53 PM   #1
5th wheel slides
My husband and I are proud owners of our first Cardinal 5th wheel and have a question about the slides. Can the slides go in and out independently, do all of them have to go out or in together?
cdewulf is offline   Reply With Quote
Old 07-23-2012, 01:56 PM   #2
TURBS's Avatar
Year and model would get more answers.
Old 07-23-2012, 04:33 PM   #3
Sorry . . . it's a 30' 2009 Cardinal 5th wheel with 3 slides. Don't have the model number right at the moment.
Old 07-23-2012, 04:46 PM   #4
B47
Not certain on yours, but our 2012 Silverback has 2 slides - bedroom and living area - and the bedroom starts exrending before the living area slide does and vice versa when retracting. They both reach their fully open/close position about the same time.
Our unit has 2 knobs that I was told can be opened/closed to isolate either slide if you do not want one or the other slide to open/close, but i have never used them.
Hope this helps.
Old 07-24-2012, 04:03 AM   #5
cardinal4fun's Avatar
Quick answer NO
I am going to guess that you have hydraulic operating slides and landing legs. With that thought in mind you can go to the hydraulic manifold and operate each line by using a power drill of some sort. That should be covered in the lippert manual.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 07-24-2012, 05:12 AM   #6
Thank you so much!
Old 09-16-2012, 09:27 PM   #7
Not sure if you got the answer you were looking for but our 2006 Cardinal has a Hydraulic manifold in the front storage bay where the landing gear is. There are four differnt pins that can be moved up or down in order to move each slide by itself. All pins down no slides move, all pins up they all move one after another or like I said with just one pin up just that slide will move. Makes it easy to get to the back bunk house without moving the bedroom slide first.
04F350 is offline   Reply With Quote
Old 09-17-2012, 05:13 AM   #8
Thanks so much . . . will check that out.
Old 09-17-2012, 09:08 PM   #9
Dallas Texas
TexasBBQ's Avatar
Each of my 3 slides has a valve at the hyd pump. I could turn one or two off if I wanted. Might come in handy when troubleshooting or making a repair.
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 09-19-2012, 10:46 AM   #10
Look for a manifold above the hydraulic tank. There maybe thumb wheels to turn in to shut off a particular slide. I beleive it was an option. That's what I have.
John & Diann
Cooper
2010 - Cardinal 3150
2011 - GMC 3500 Dually
Cardinal RV Club
Travelers is offline   Reply With Quote
Old 09-19-2012, 01:20 PM   #11
Originally Posted by Travelers View Post
Look for a manifold above the hydraulic tank. There maybe thumb wheels to turn in to shut off a particular slide. I believe it was an option. That's what I have.
I found a pic of mine.
John & Diann
Cooper
Cardinal RV Club
5th wheel
