Old 04-26-2018, 11:23 AM   #1
AC Maintenance
2008 Cardinal been is storage 1 and 1/2 years. Cleaning up for trip. Operated AC and seems to be cooling however wandering if there are filters or some cleaning that should be done?
2008 Cardinal 30RK fiver.
2009 Chevrolet 2500HD DuroMax
2009- 42 days; 2010-40 days, 2011- 40 days. 2012- 30 days,
2013- 14 days, 2014- 21 days, 2015- 42 days
2016-17 days, 2017-zero days
Wanderer is offline   Reply With Quote
Old 04-27-2018, 05:22 AM   #2
you can get up on the roof and remove the shroud and make the sure cooling fins are free of dust. I looked at mine late last summer, and there was quite a bit of cottonwood fluffies clogging the fins. Internally, if the AC isnt ducted, or at least has the removable panel right below it, you can clean the refrigerating fins too. They can get compacted with dust on the intake side. On my old trailer, I've used an old toothbrush and vacuum to clean them out.
Dave
2017 Cardinal 3850RL Mocha Pearl full body paint
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
djousma is offline   Reply With Quote
Old 04-27-2018, 07:10 AM   #3
cavie's Avatar
There should be a removable filter on the inside of the unit accessed by a removable levered panel in the ceiling unit. Remove the rooftop cover and clean debris from the unit.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 05-03-2018, 01:10 AM   #4
Hi, good thing got up on top and checked out the a/c. first the shroud was cracking in several screw holes, on the main body top and the unit was extremely dirty with wasp nestings, luckily no wasps. Brought shroud down to repair and while doing that we had a good rain so cleaned the a/c unit up pretty well. Epoxy used on cracks and some light metal reinforcing. Reinstalled today, will be on road soon, will find out how well a repair job I did. Those new shrouds go for around $150.00 plus!!!!! Thank you all for ideas & suggestions.
maintenance
