Are you talking about relaxing the springs with an air ride suspension?
I hate this spell check it does what it wants,
I meant to say Are you talking about replacing the springs with an air ride suspension?
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
Look at Center Point Air System from LCI, I put the Center Point with shocks on a 2010 CC 36RE and it does make a big difference in the coach ride and pulling. It does nothing to increase load or anything like that but you will notice a big difference on things in the coach. I will be adding the same system to our new 2015 CC 36 CKTS when we get to Goshen this year.
I put mor ryde 4000s on mine much better than 3000s the 4s have up to 4" of travel and a crossbrace theat helps reduce frame flex. Cost about 400 on line also get the heavy duty shackles much stronger then original with brass bushings. Grease zerts at all pivot points l put it on myself requires no special tools. You can also buy additional braces to go across at end of spring hangers
Really helps reduce sway also.
