Old 04-25-2015, 01:54 PM   #21
DDC
DDC's Avatar
Originally Posted by DDC View Post
Are you talking about relaxing the springs with an air ride suspension?
I hate this spell check it does what it wants,
I meant to say Are you talking about replacing the springs with an air ride suspension?
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 04-25-2015, 02:02 PM   #22
Forbes's Avatar
Look at Center Point Air System from LCI, I put the Center Point with shocks on a 2010 CC 36RE and it does make a big difference in the coach ride and pulling. It does nothing to increase load or anything like that but you will notice a big difference on things in the coach. I will be adding the same system to our new 2015 CC 36 CKTS when we get to Goshen this year.
Forbes is offline   Reply With Quote
Old 06-03-2015, 12:01 PM   #23
carlg
Originally Posted by selkirk awards View Post
I wish to install air bags on my Cardinal need HELP where to buy???????
I have the Airborne and have found it to be better than without. You still get shocks from bad roads no matter what you have.
Carlg is offline   Reply With Quote
Old 06-30-2015, 04:30 PM   #24
jacknife's Avatar
I put mor ryde 4000s on mine much better than 3000s the 4s have up to 4" of travel and a crossbrace theat helps reduce frame flex. Cost about 400 on line also get the heavy duty shackles much stronger then original with brass bushings. Grease zerts at all pivot points l put it on myself requires no special tools. You can also buy additional braces to go across at end of spring hangers
Really helps reduce sway also.
jacknife is offline   Reply With Quote
5th wheel, air bags, wheel
