Old 04-03-2015, 10:57 PM   #1
Backing my 3150 Cardinal into camp site
This my first year owning a bigger 5th wheel. I am having a hard time trying to back it in my site at a campground. The roads are fairly narrow and I am 37 feet long. Any tricks for something that long?
litz is offline   Reply With Quote
Old 04-04-2015, 05:07 AM   #2
Salt Shaker's Avatar
Take your time. Use a spotter that you can communicate with. Hand signals are great but I love blue tooth on my truck. The wife gets on her phone and calls me hands free.
Ever body has been there. Check your overhead for clearance as well.
If you get jammed up pull forward and reposition.
Salt
2014 Silverback 29RE, 2014 Ram 2500 CC 4x4 Hemi 6.4 auto w/ airbags, B&W Companion. Saltwater boats and rum like any good pirate.
Lose the 2nd and the rest will follow.
Salt Shaker is offline   Reply With Quote
Old 04-04-2015, 05:57 AM   #3
StoneyG's Avatar
I'll echo what Salt Shaker said and just say that narrow roads just make it hard. Time and practice will make it easier.
StoneyG is offline   Reply With Quote
Old 04-04-2015, 07:03 AM   #4
Oakman's Avatar
Hopefully your campsites arenít set at 90 degrees to the road. A few campgrounds I stay at have narrow roads with 90 degrees sites, those are a bear to get into.
One thing I do is drive an arc pattern as I drive passed the site. In other words, approaching the site I angle the truck toward the campsite, as I pass the site I angle the truck away from the campsite until Iím clear of the site and in a position to start backing. This leaves the fifth wheel already slightly angled toward the campsite. I hope I explained this so it is understandable. Regardless, big rigs and narrow roads are problematic.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 04-04-2015, 12:57 PM   #5
Look on YouTube for "the Scoop" maneuver
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
Big Vic is offline   Reply With Quote
Old 04-04-2015, 01:17 PM   #6
How far past the campsite do you pull your rig before you start backing up? I had a 35 ft cougar 5th wheel and it seemed easier than my cardinal.
Old 04-04-2015, 01:34 PM   #7
BOBFIDY's Avatar
Just my $.02.....I try to concentrate where the trailer tires are in relation to the drive/grass and maneuver to keep the tires on the drive/slab.
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
Old 04-04-2015, 05:03 PM   #8
ColoradoRick's Avatar
The scoop really does work! My old RV parking spot wasn't angled so I always had a hard time getting it right until I tried this...really works!!
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
6-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
ColoradoRick is offline   Reply With Quote
Old 04-04-2015, 07:16 PM   #9
With all the new backup cameras that are out there you can get two camera system and always use the driver side to back into as it is allot easier to see
b1hasj83 is offline   Reply With Quote
Old 04-04-2015, 07:37 PM   #10
Rodney & Patty
Interesting - I never knew that technique was the scoop. I started making that maneuver many years ago on the farm with tractors and spreaders. The video shows the idea of the swing in before pulling away to properly align the trailer axles with the site entry. They do show the TV pulling away at a sharper angle than what is practical on most campground roads but it does give a beginner the right idea for the ideal environment. I like what I read above about having the spotter on the cellphone - a great way to incorporate modern technology into the process. Another mention was made about 90 degree entries - sometimes entryways are even angles the wrong way. If I run into this I will have my spotter block the roadway while I go down and turn around - even if it's a one way, by blocking the roadway - oncoming traffic is a non issue and the reversal may make the entryway angle easier to approach... Experience is priceless but there is only one way to get it.
rdenslow is offline   Reply With Quote
cardinal
