Old 04-13-2011, 01:57 PM   #1
best way to flush water systen on 03 cardinal
just bought a 03 cardinal, I do see anti-freeze in the lines. can I hook up to my house lines and run water through the system or is that to much water pressure? Of course there was no manuals - it was a repo. So far everything looks good and it seem to have been well care for.
On my old camper it only had holding tank and pumps and did not hook up to city water like this one.
dixie246 is offline   Reply With Quote
Old 04-13-2011, 02:03 PM   #2
Yes, you can hook up to any outside faucet however, you do need a pressure reducer/regulator. Available at any RV place & most Wal~Marts $8 to $10. Hooking up to city water works well - a good way to get air out of the lines. When filling the hot water heater hold the pop off valve open to let the air escape. When water starts running out release pop off valve.
Everett & Joan after 60 years together. 2004 1/2 ton Chevy & 2011 Rockwood 1809S
Number of nights camped in 2012 65
Number of nights camped in 2013 82
Number of nights camped in 2014 105!
Number of nights camped in 2015 81
Emptypockets is offline   Reply With Quote
Old 04-13-2011, 04:56 PM   #3
cardinal4fun's Avatar
In addition to other post, you will also want to flush not only the lines but the fresh water holding tank. Just like you did with your other camper.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 04-14-2011, 08:03 AM   #4
Traveler II's Avatar
You also might want to add water to your fresh water take and let the pump run to flush out the lines that the pump is connected to.
Jim and Jane
2008 Cardinal 30TS
Trail Air Pin Box, Center Point Suspension
Reese 18K hitch - Garmin 1690 GPS
2008 Chevy 2500HD 4x4 Duramax/Allison, Long Box, Smartair
Nights camped in 2011: 120
Traveler II is offline   Reply With Quote
