Old 05-21-2016, 03:03 PM   #1
Black and grey tank question
We have a 2016 cardinal 3825FL. There are 3 light indicators for the wastewater labeled galley, grey and black but there is only water in 2 of the tanks when it's time to dump. Black works fine, bit shower,galley and bathroom sink are all going in one and doesn't hole much at all. Is something wrong?
NEDWARDS1959 is offline   Reply With Quote
Old 05-21-2016, 03:15 PM   #2
Oaklevel's Avatar
Not familiar with your set up.
Really not enough info but there should be 3 dump handles The Galley is kitchen waste water, grey bathroom sink / shower and black- toilet.
When you say the tank is small what size should it be and could be your showering habits making it fill faster. Do you take Navy showers ?? or leave the water run during a shower. If you leave the water running your tank will fill faster.
2005 Dodge 3500 Cummins
2013 Puma Unleashed 356 QLB
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
Old 05-21-2016, 03:33 PM   #3
asquared's Avatar
Hello and welcome to the FR forums. The site team has moved and renamed this thread to get you more help.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 05-23-2016, 06:12 PM   #4
Had the same problem. Was told that the third tank (grey) is plumed for the clothes washer, that we don't have. What is worse, we also have a dishwasher going into the galley tank along with the shower, and both sinks. Dumb setup, if anything there should have been a third grey tank.
Joe & Joan
Fredericksburg, VA
F350 PSD DRW & Cardinal 3825FLR
CruiserJoe is offline   Reply With Quote
Old 05-23-2016, 09:28 PM   #5
There was a recent thread about some trailers where the second grey tank was plumbed to only the outdoor kitchen sink. Sounds similar.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 05-27-2016, 09:45 AM   #6
Leonandpandora's Avatar
I have the same floor plan as you. The second grey tank is for the washer hook up. It is not an Ideal set up to be sure.
If you are hooked up to park sewage we leave the grey valve open and make a slight bend in the line like a u close to the park hookup to help with keeping gas out. Of course water in the p traps would do it anyway but this is Just another stopping point .
Just simple everyday usage without the dishwasher fills the grey fast enough. With the dishwasher I think they should have plumbed the two grey together or plumbed the dishwasher to the back one.
Design flaw on manufacturers part.
Otherwise it is a super unit.
2016 F350 6.7 Drw 4.30 gears
2016 Cardinal 3825 FL
2011 Big Country 3500RL...Sold
DW, 2 Spoiled Beagles IZZY and Pup Pup,
And Hillbilly Bob an American Bobtail Rescue Cat.
Seeing America one jobsite at a time..
Leonandpandora is offline   Reply With Quote
Old 05-30-2016, 10:11 AM   #7
I also have a 2016 Cardinal 3825fl. Does anyone know what size the rear tank is?
Rsavino is offline   Reply With Quote
Old 06-01-2016, 12:02 AM   #8
jacknife's Avatar
Go to cardinals website and look up your model and you can get the specs for your tanks there
jacknife is offline   Reply With Quote
Old 06-01-2016, 06:05 AM   #9
Rear waste tank
The specs don't break down the 2 separate gray tanks
Old 06-01-2016, 02:14 PM   #10
I certainly hope this isn't the case. What a waste that would be! The doc I've read says 65+12 fresh water, 40+40+40 black/gray/gray. We are about to take delivery of our 2017 3850RL, and it will have washer/dryer, but I'd never consider using it while on tanks(non-full hookup).
djousma is offline   Reply With Quote
tank, black
