Old 11-27-2016, 08:16 AM   #21
VinceU's Avatar
My problem was different. Valve in a hollow wall dribbling-once only. In brief I had accidentally left the flush valve barely cracked open. I saw a drool at the valve cap. Opened valve fully open and fully closed no leak. Repeated leaking supply valve setting and again. Seems if supply pressure is very low, the vac breaker will seep through its exhaust port. Never s drip since.
Old 11-27-2016, 08:54 AM   #22
Toy-aholic
Take a look through this thread I posted a while back....
http://www.forestriverforums.com/for...ers-70716.html
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 11-28-2016, 01:44 PM   #23
I couldn't find your comments??
1010 is offline   Reply With Quote
Old 11-28-2016, 02:02 PM   #24
When I found water had gotten into the storage bay, the water was concentrated under the toilet, however there was no evidence of water leaking down from the pipes. If the water seeped under the rear bulkhead it did not weep up the carpeted bulkhead. The contents were wet, the floor was wet, quite a bit of water came from somewhere but I could not see where it came from. The dealer said they ran water for 45 minutes & found no leaks, so I am sure they will balk at working on it further, meaning I will have to find it.
After dumping & flushing the black water tank, I often close the black water valve & fill the tank up about half way, then open the valve to get the "rush" to push more solids out of the tank. I assume there is no added water pressure to the black water flush line when I am doing this or could this be part of the problem? The water has leaked either way.
I am not sure when I will get my trailer back, been at the dealers since early Dec.
Thanks for any info.
Old 12-01-2016, 11:35 AM   #25
In answering 1010's reply, my water leak is exactly like you describe. My dealer states the check valve can stick and will then leak. If it comes loose from traveling, the valve will work just fine.
Cannot understand why builders put these valves in unaccessible places. Plus, my dealer doesn't know exactly where they are located.
Thanks for the replies.
cardinalrancher is offline   Reply With Quote
Old 12-01-2016, 11:40 AM   #26
Left Coast
Mine was located in bathroom vanity.....they need to be high
Old 12-01-2016, 12:03 PM   #27
Thanks for the reply, Bob.
Yes, I agree they must be high to function properly. I have looked in my bathroom vanity, under the shower compartment, and behind 2 false walls. But if the valve is located in the bathroom area, I would surely see water on the floor.
Old 12-01-2016, 12:10 PM   #28
Left Coast
My vanity has a laundry Shute to basement....had the compartment door open while using the flusher and noticed water dripping into the well just inside door....so I started snooping....have seen where some are located behind shower water fixture....can you access the hose from flush port and follow it?
Old 12-01-2016, 12:43 PM   #29
IF you have a back flow valve at the black tank flush connection, you can just remove the vent valve completely and all the excess hose and connect the inlet directly to the black tank flush hose. I did 2 yrs ago and it works better.
Name:	Black tank back flow valve close up.JPG
ID:	126018   Click image for larger version
Name:	Black tank back flow valve 1.JPG
Old 12-01-2016, 12:51 PM   #30
Yes, Bob, I can follow the hose from the docking station until it goes up through the floor and don't know where it goes from there. It appears to be near the bathroom but I have never seen water anywhere in the upstairs living area. Looking from the docking station, the water is leaking down the hose where it goes through the floor.
Old 12-01-2016, 01:28 PM   #31
Do you have a back flow valve at the hose connection like the picture I showed?
Old 12-01-2016, 08:31 PM   #32
Thanks of the pictures. What am I looking for, a check valve or a vacuum breaker, are they the same? What do they look like and how do I determine if it is bad, run the black water flush I assume? Your method (as well as others here) seems to be the answer. What is the purpose of the check valve or vacuum breaker if all that is needed is a back flow valve at the inlet?
Old 12-01-2016, 09:15 PM   #33
Originally Posted by 1010 View Post
Thanks of the pictures. What am I looking for, a check valve or a vacuum breaker, are they the same? What do they look like and how do I determine if it is bad, run the black water flush I assume? Your method (as well as others here) seems to be the answer. What is the purpose of the check valve or vacuum breaker if all that is needed is a back flow valve at the inlet? Thanks
You're mainly looking for something like the picture I posted. If you have that, you can forget the vacuum breaker and just plumb into the flush hose. As to why have both, probably some fed regulation like the minimizer washer in all faucets, SENSLESS!
Old 12-02-2016, 01:21 PM   #34
To reply to oldcoot, no I do not have what you show. There is no valve at the dock station connector.
Old 12-02-2016, 01:54 PM   #35
Left Coast
My factory one was a black plastic 90 degree valve with a hose barb on each end....they leak where the two halves are glued together.......one plastic vavle with 2 functions
Old 02-16-2017, 04:34 PM   #36
OK this is what mine is doing
2016 Cedar Creek 36CKTS
2013 F-450
emtp82 is offline   Reply With Quote
black, black tank, black tank flush, leak, tank, water
