Old 10-29-2016, 08:51 PM   #1
black tank flush leaks water
I have a Cardinal 3850, 2014 model and when I apply water pressure to the black tank flush connector, it leaks water in the basement area. Took down the wall next to docking station. Noticed the flush line goes up through the floor near the fuse box/breaker box. Anyway, water is running down the hose where it goes through the floor and then ends up in the basement area. My dealer says there is a check valve in there somewhere and is probably leaking. Doesn't know where it might be. Has anybody had this problem or have a clue where I can find the check valve? Thanks for any help on this!!
cardinalrancher is offline   Reply With Quote
Old 10-29-2016, 08:58 PM   #2
It happens on my 36CKTS and was told some leaking was normal. I beg to differ, however, it isn't a big enough issue for me to take it in to get it looked at.
2016 Cedar Creek 36CKTS
2013 F-450
emtp82 is offline   Reply With Quote
Old 10-29-2016, 09:48 PM   #3
Left Coast
It's not normal.....look in bathroom vanity....It's a air admittance / backflow plastic valve....
Old 10-29-2016, 09:50 PM   #4
Canadian Member
That's fairly common. The previous owner of my TT replaced it with a 90 deg bend and I use this backflow preventer on my dedicated black tank flushing hose.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
itat is online now   Reply With Quote
Old 10-29-2016, 10:05 PM   #5
Thanks for the responses everyone!! I have looked in the bathroom vanity, under the shower and around the toilet. Sure would be nice if the builders would have a plumbing diagram.
Thanks again!!
Old 10-29-2016, 10:08 PM   #6
Canadian Member
It should be right behind and about a foot above the outside inlet port. It may be in a cabinet or behind a panel.
Old 10-29-2016, 11:19 PM   #7
GLCM Warrior
Lefty59's Avatar
On our Wildcat (which leaked initially too) the vacuum break for the black tank flush was behind the valves for the shower according to the dealer that fixed it. They had to remove the shower faucet to gain access to the valve.
Best of luck!
2014 Wildcat 312QBX
2014 Ford F350 SD 4X4 CC LB 6.7L PSD
Bob & Debbie, USAF Retired
Lefty59 is offline   Reply With Quote
Old 10-30-2016, 01:06 PM   #8
alsimmon11's Avatar
Tank flush leak
Having the same problem with my Sabre 330. Once I get it back from Giant RV after an awning switch problem I will look at that valve. Would have them do it but close to a month for an switch is too much.
alsimmon11 is offline   Reply With Quote
Old 10-30-2016, 01:10 PM   #9
Telstar's Avatar
We have a 2005 Cardinal 36TS LX and I had to replace the sprayer. I found the verticle tube went halfway up the wall behind the shower to where the vacuum breaker is. Then it went back down to the tank. Instead of removing the under belly cover to get to the tank I unscrewed the floor of the storage area which provided full access to the tank area. My problem was a claugged sprayer so I replaced it with the one Camping World sells. It spins and does a much better job. I tested the action of both by connecting them to a garden hose.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
Telstar is offline   Reply With Quote
Old 10-30-2016, 01:19 PM   #10
Follow the water line for the BTF you are looking for this! It is NOT Normal for any Water to leak Inside any RV! Youroo!!
Old 10-30-2016, 03:09 PM   #11
sfsgm's Avatar
X2. I just shook my head when I read that it's normal for water leakage inside a trailer.
2016 Nike Take Down Wrestling Shoes
42 ft square Dollamur high school wrestling mat
sfsgm is offline   Reply With Quote
Old 10-30-2016, 04:56 PM   #12
I guess I should phrase it better, mine leaks at where the hose connects to the flush
2013 F-450
Old 10-30-2016, 05:00 PM   #13
sgtlm17's Avatar
There is a rubber washer where the hose connects. Mine was not seated properly when I got my rig. Just remove three outer screws to remove black rinse hose connection from rig. And it screws right off to get to the washer.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 10-30-2016, 06:51 PM   #14
Not sure if it is the same but on ours the flush was leaking at the bulkhead connector at the wall of the tank. I ordered a new bulkhead connector and when it arrived was going to replace the connector. I removed the hose where it connected to the bulkhead connector and noticed the line that goes trough the wall of the tank was loose. Resembles a garden hose connection. I turned it about half turn and it tightened. I reconnected the hose to the bulkhead connector. I connected the garder hose and turned it on. No leak. So now I have a spare which I will probably never use.
markb422 is offline   Reply With Quote
Old 11-06-2016, 08:37 PM   #15
Thanks everyone for the responses!! Since I have posted this thread, a fellow camper with a 3850 told me he thought the check valve was next to the tank itself. The only access was from the under belly. If that is the case, I cannot understand why the tank flush hose is routed up through the floor. With the wall down behind my docking station, I can see water running back down the hose where it goes through the floor. It appears to go through the floor somewhere around the shower or vanity. If this check valve was/is above the floor, I would think there would be water visible from the living area. This problem has me baffled.
Old 11-06-2016, 09:18 PM   #16
VinceU's Avatar
To act as a vacuum breaker it must be located about 36" above the tank inlet. The vac breaker is then installed about knee level above the coach floor level in a hollow wall or cab, maybe with a false wall. The leak or drool can fall straight down through the pipe penetrations.
Old 11-06-2016, 09:41 PM   #17
GreenImp's Avatar
Send a message via MSN to GreenImp
Another vote for "Mine leaked when new"! Like many others, my leak was simply a loose fitting at the vacuum breaker. It was difficult to access due the small hole you have to reach through (behind the shower valve).
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 11-06-2016, 09:42 PM   #18
Mine was leaking in the wall. I bypassed the vacuum breaker. Look under the trailer where the connection for the black tank sprayer goes through the skirt. The water line goes up into the trailer and comes back down in the same area then goes under the trailer to the tank. Connect the line from the spray connection directly to the one that goes to the tank, bypassing the lines that go up to the inside of the trailer. This will eliminate the leak and the sprayer will still work.
wvcampers is offline   Reply With Quote
Old 11-06-2016, 09:43 PM   #19
Left Coast
Did away with it and about 12' of extra hose.....installed a brass backflow valve for a house
Old 11-26-2016, 09:50 PM   #20
I have not been on the forum for quite a while, our 2017 Cardinal 3250 RLSB has the same issue, initially the water leaked from behind the heater vent, the dealer fixed it, however water still leaks and drips down the inside of the skirting. Twice it has leaked into the bay compartment. Our dealer said they ran the back flush for 45 minutes and could not duplicate. Thank you all for you postings, I now have something to work with on getting the leak repaired by the dealer.
1010 is offline   Reply With Quote
black, black tank, black tank flush, leak, tank, water
