Old 08-21-2018, 08:21 PM   #1
Black tank flush sprayer leaks water
Does anyone have experience with replacing the sprayer that is attached to the tank? Mine leaks and I can't use it. My dealer says some of those were "roto-spun" and can't be replaced. Need to replace complete tank. Looks like an H of a job to replace the tank. Any thoughts or suggestions?
Thanks!!
Keith
2014 Cardinal 3850
cardinalrancher is offline   Reply With Quote
Old 08-22-2018, 10:17 AM   #2
The Newsoms's Avatar
Where is the leak?
The Newsoms is offline   Reply With Quote
Old 08-22-2018, 08:13 PM   #3
It leaks at the fitting that is flush with the tank. Appears the female fitting is cracked.
Old 08-22-2018, 09:13 PM   #4
If you search on this forum, youíll find people who have upgraded their black tank sprayer. That might be worth doing if youíre going to have to mess with it anyway. I just use a wand to wash ours out because I donít trust the sprayer to do a good job.
Old 08-22-2018, 09:31 PM   #5
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Here is your fix
Plasti-Mend Plastic Repair Products
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 08-22-2018, 09:44 PM   #6
Originally Posted by cardinalrancher View Post
Does anyone have experience with replacing the sprayer that is attached to the tank? ..... Looks like an H of a job to replace the tank. Any thoughts or suggestions?
aftermarket flush unit "Quickie Flush", ... easy to install, and works great, ... there is a similar aftermarket model called "Tornado", that rotates, but I've read several reviews where the complaint is that it freezes up and stops rotating, .... guess then you have a "Quickie Flush" by default, ...
https://www.amazon.com/Camco-40123-Q...=quickie+flush
https://www.walmart.com/ip/Camco-Qui...enter/29764338
fella10 is online now   Reply With Quote
Old 08-23-2018, 04:57 PM   #7
Mine was leaking so I bought a new one to install. As I was about to remove the old one I noticed it is just like a hose connector at the bulk head fitting. Tightened it and it has not leaked since.
markb422 is offline   Reply With Quote
Old 08-26-2018, 07:53 AM   #8
Cardinalrancher,
I sent you a private message
redbyrd is offline   Reply With Quote
black, black tank, black tank flush, flush, leak, tank, water
