Old 07-25-2016, 05:30 AM   #11
Sg6923's Avatar
Final update: I fixed it!! Went camping last weekend and withe the help of my brother started focusing on connections. Finally zeroed in on the truck plug and took it out. Low and behold when I disconnected it from the wiring I found two pins that were bent at 45 degrees. I straightened and it worked perfectly. I have no idea when or how it happened but figure I've been driving without left turn/break for many months.
Sg6923 is offline   Reply With Quote
Old 07-25-2016, 05:57 AM   #12
After "Hook up" a Member should turn on their "4 Way Flashers" and do a Walk Around,this will tell you if the "Stop/Turn" are working! Lots of people Do NOT use their "Turn Signals" when Merging or Changing Lanes but it IS the LAW and Sure Helps people know Your Intentions! Youroo!!
brakes, replacement
