Old 07-03-2016, 08:44 AM   #1
Sg6923's Avatar
Brake/signal Replacement Lens
I hope I'm in the right topic. I'm having a terrible time finding a replacement lens for my 2010 3625 5th wheel. It's a Glo Brite P/N 9541. Do any of y'all have a source? Etrailer and Camping World don't have. I haven't contacted Forest River yet. If there's a crossover I'd like to know that as well. Thanks!!!
Sg6923 is offline   Reply With Quote
Old 07-03-2016, 09:00 AM   #2
Ford Idaho's Avatar
Got a picture of it?
Time to upgrade?
https://www.google.com/url?sa=i&rct=...67640683084733
Old 07-03-2016, 09:28 AM   #3
Sg6923's Avatar
Name:	ImageUploadedByForest River Forums1467556053.446244.jpg
Yes. Hope you can see it.
Old 07-09-2016, 09:33 PM   #4
Sg6923's Avatar
Well, I found a light but that wasn't the problem. Now investigating the fuses. They don't appear to be blown but had some kind of coating on the contacts so will replace those tomorrow. If that's not it will move to the plug in back of the truck. The passenger side works fine and the running light works. But not the signal/ brake.
Old 07-14-2016, 09:48 PM   #5
jacknife's Avatar
Get some led replacements . They will plug right in same screw patteren brighter less juice and illuminate faster. $18 .00 per pair. E trailer .com.
jacknife is online now   Reply With Quote
Old 07-15-2016, 07:41 PM   #6
Sg6923's Avatar
Great idea. I'm going to do that but have determined the lens is not the problem. Replaced fuses in the truck related to signal/ break. Plan to check for any inline fuse and then move on to the plug in the truck to see if I have any dead spots. I'd so will either check connection or replace. If no problem check the cord in the camper. If that isn't it will likely hire a pro. Hoping for the best though. The LEDs do look good!
Old 07-15-2016, 07:51 PM   #7
Flybob's Avatar
Make sure the LEDs are compatible with the turn signal controller in your TV.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 07-16-2016, 05:33 AM   #8
Sg6923's Avatar
TV?
Old 07-16-2016, 05:44 AM   #9
Originally Posted by Sg6923 View Post
TV?
TV in your case would be a Ford 250! Youroo!!
Old 07-16-2016, 06:01 AM   #10
We had to hire a Pro while on a long trip in Vermont! All TT lights would go out blow a Fuse in Truck! New Truck and New TT" SOB"! Truck Dealer says OK,TT Dealer says OK,the Lights were Very Inconsistent about "Blowing the Fuse" Only when Moving "5 miles or 25 miles"? you would Never know,which was Very Bad because you have NO brake/turn lights! Found/called a Mobile Repair who had worked for the SOB Dealer and he knew Exactly where the WIRE was Shorted/Rubbing in the enclosed underbelly! I paid him and the TT MFG paid me ! Real pain but there are LOTs of Sharp metal areas they run our wires through! Youroo!!
brakes, replacement
