Old 04-27-2016, 04:01 PM   #1
Brakes, adjusting?
Got about 7500 miles on all new brakes on or Card. Getting ready to go again, probably nmt 700 miles this time. Wondering IF I should adjust the brakes and how the easiest means of accomplishing that adjustment?
Thanks,
Wanderer
2008 Cardinal 30RK fiver.
2009 Chevrolet 2500HD DuroMax
2009- 42 days; 2010-40 days, 2011- 40 days. 2012- 30 days,
2013- 14 days, 2014- 21 days, 2015- 42 days
Wanderer is offline   Reply With Quote
Old 04-28-2016, 12:57 PM   #2
97flhtcui's Avatar
If it is a new Cardinal your brakes are self adjusting.
2011 Ford F-250 6.2l gas 373 rear end
2015 Cedar Creek 34RL
97flhtcui is offline   Reply With Quote
Old 04-28-2016, 07:06 PM   #3
It is not a new trailer, its a 2008, new brakes with new brakes but with 7500 cross country miles.
Old 04-28-2016, 08:40 PM   #4
97flhtcui's Avatar
OK, lift each wheel, spin then adjust till it drags then back off till it just barely rubs. Or adjust till it stops spinning then back off till it you can spin again. My 2009 card had self adjusters so I never needed to adjust.
Old 05-01-2016, 04:11 PM   #5
Witch Doctor's Avatar
I agree, time to check them easy to do, I can even do that, better then warping your TV rotors. I have done that once already
Sent from my SM-N920V using Tapatalk
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 05-12-2016, 12:20 AM   #6
jacknife's Avatar
You should be adjusting them no later then 3000 miles
jacknife is offline   Reply With Quote
Old 06-04-2016, 12:31 PM   #7
wayne nichols's Avatar
Self Adjusting Brakes
I have a 2008 Cardinal 30RKLE also. about 2 months ago I changed my manual adjust brakes to the forward self adjusting. My Cardinal came with Al-KO T52 axles, Dexter makes a direct replacement for a real good price I got mine for $115 a hub. For anyone not wanting to get dirty or wants a piece of mind its the way to go. This removes the worry that they brakes aren't set right.
Leah, Wayne, Frankie & Max
2008 Ford F-450 King Ranch 4X4 6.4L
2008 Cardinal 30LE
wayne nichols is offline   Reply With Quote
Old 06-04-2016, 12:35 PM   #8
SKnight's Avatar
This does the trick. Though, don't trust your self adjusters too much, they keep them close and functional but not optimum.
Old 06-06-2016, 11:01 AM   #9
97flhtcui's Avatar
I was a auto mechanic and did a lot of drum brakes and found the self adjusters do a great job as long as you backed up enough to activate them. On a trailer they work even better because you are spending a lot of time in reverse. That can be confirmed when you pack your wheel bearings every year.
Old 06-06-2016, 11:32 AM   #10
Hey now I back up my truck/car a LOT more than our Trailer! We are normally "On the Go" in the Forward Direction!I use the Spin till lock up/then back off Method,to adjust the drum brakes! Youroo!!
brakes
