If your tank doesn't have min/max lines, mark the fluid level with slides all the way in, then move slides out and mark level. You don't want the tank to be dry and suck air. If you have sufficient oil in tank when slides are out, all is good. If you're low add a little, but remember that the tank will fill when the slides come in.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
