Old 12-30-2017, 11:26 AM   #1
The Newsoms's Avatar
Cardinal 3025FL low water drains
I can’t find them. Found the fresh water drain, no problem. I’m assuming it has some somewhere and I’m over looking them. Anyone have guidance? ~ Teresa
The Newsoms is offline   Reply With Quote
Old 12-30-2017, 11:35 AM   #2
Mr. Dan's Avatar
I don't have a Cardinal... but I suspect you'll have to get under the unit to find your low point drains. Mine are inconveniently located about mid-way left to right under the trailer and just in front of the axles. One blue tube, one red tube -- both with screw on/off caps.
Old 12-30-2017, 01:14 PM   #3
X2 on Mr. Dans post, they may not be sticking down below the bottom. On My 33IK they are right beside the steps between the aluminum skirting and frame.
Rich5117 is offline   Reply With Quote
Old 12-30-2017, 01:50 PM   #4
Thanks for the reply’s. I’ll crawl around and find them. Supposed to be 12 degrees Sunday night. VERY unusual for us. Usually don’t have to worry about it. ~ Teresa
Old 01-01-2018, 10:30 AM   #5
Havasu Bill's Avatar
Look next to and underneath your utility compartment where your Tank handles are at. That’s where mine are on my 3250 and they’re easily accessible.
Havasu Bill is offline   Reply With Quote
Old 01-02-2018, 09:15 AM   #6
we have a 2015 cardinal model 3025fl. the low point drains are on the passenger side just forward of the front door. you can't see them from the side as they only stick out a small amount and are higher than the bottom shielding. you don't have to crawl under the trailer, but you have to get down on a knee and be able to look up behind the bottom shielding.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 01-02-2018, 09:49 AM   #7
Did you find them?
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
cardinal, drain, water
