Old 06-05-2012, 09:57 PM   #1
Cardinal 3550RL
The wife and I are considering the purchase of a Cardinal 3550RL but we're not sure if our 2008 F350 is capable of towing it. Is anyone pulling something similar with an F350?
John Taylor
2019 Newmar Bay Star 3609
2018 Cardinal 3350RLX - sold
2013 Cardinal 3030RLS - sold
jtaylor1920 is offline   Reply With Quote
Old 06-05-2012, 10:09 PM   #2
Is it a dually?
That fiver has a GVWR around 15K so you will need a dually to handle it.
Old 06-05-2012, 10:49 PM   #3
Hello and to the forums. While I can't answer your question specifically, I can suggest you a search on here for "tow calculator" and see what you get. Several post on here about what can tow what. You will need empty weight, and max weight of tow vehicle and camper in order to input good data so your output is also good data. I will say this, it arrived at the dealer by means of a one ton dually pick up, and it came from Indiana. Now, can your truck tow it? You have to decide, and be responsible for the consequences, whatever they may be.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 06-06-2012, 06:54 AM   #4
Donn,
Thanks for the reply. Our truck is a single axle so I guess we're back to our search for the right unit. Thanks again.
John
John Taylor
Old 06-06-2012, 06:56 AM   #5
Thank you for the references, I'll definitely check them out as the safety of my family and fellow travelers is a priority for me.
Thanks,
John
John Taylor
Old 06-06-2012, 08:25 AM   #6
Arrow
Originally Posted by jtaylor1920 View Post
Donn,
John
John,
While I am not telling you that it can't be done and before you cross it off your list, load up your truck like you will be traveling and go to the scales. Get the rear and front axle weights plus the total weight of your truck. From those numbers you can find the FAWR and RAWR plus the trucks GVWR and make some educated guesses if you will be comfortable towing the 3550RL. when calculating a trailers weight please remember to ignore the "yellow" sticker, and any terms that may be used except GVWR. While you may never reach the trailers GVWR (yea right) you will have a safe idea of how heavy your combination will be when loaded and ready to travel. Also ignore anything a salesman tells you as they are in it for the money.
As an example, my fiver has a GVWR of 13,750 an axle dry weight of 8781 and a dry pin weight of 1742. Based on those numbers it appears on paper that this fiver could easily be pulled with a 3/4 ton. But wait. Actual ready to camp numbers are Pin weight 3000+, ready to camp weight 13,500 pounds. Yup the pin weight nearly doubled, simply because I added a few things, (no generator) and the advertised weights were notoriously inaccurate. so long story shortened, I gave up on towing with a 3/4 ton truck after three years and 8700 miles in favor of a dually. I have never looked back or regretted my decision to get enough truck for my load.
Old 06-06-2012, 09:16 AM   #7
Originally Posted by donn
John,
Donn,
Thanks again. We recently sold our 29' class C and had been considering going to an A, but to get some of the amenities we wanted we quickly priced ourself out of a reasonable budget since I really wanted a diesel for mileage and hill climbing power. I'll pull my numbers together and see if this model fits and is safe to tow. We'll also take any salesman "advice" with more than a bit of general skepticism.
John
John Taylor
Old 06-06-2012, 09:46 AM   #8
Let me know what you come up with. Ee looked at a 3550rl last year a couple traded for a mh and really liked it. Just not in my budget as I was laid off for the second time in Sept. Retired now so we are going camping for two months.
Old 06-06-2012, 09:47 AM   #9
camper_Lucy's Avatar
We would need more details on the F350 to help you, engine, cab design, srw or drw, gears, etc.
If you want to post those items we can help navigate you to number.
Here is the link to the 2008 F350 Towing specs.
https://www.fleet.ford.com/showroom/...guideDec06.pdf
2011 GMC 3500HD 4x4 Crew DRW Duramax
Pullrite 20.5K
2012 Sierra 365SAQ
2006 Police Roadking FLHPi
camper_Lucy is offline   Reply With Quote
Old 06-06-2012, 10:27 AM   #10
Camper_Lucy,
Thank you for your reply. I have pulled the following information together:
Engine: 6.4L V8 turbo diesel
Cab: 4 door crew cab
SRW or DRW: It is a SRW truck
Gears: 3.73
Bed length: 8 feet
According to the door sticker:
GVWR: 11,500
Front GAWR: 6000
Rear GAWR: 7000
We generally travel and camp light in my opinion. Just my wife and our 3 small dogs. For the most part we don't carry water and our rig won't have a generator installed since we tend to stay at locations that are full service (the wife doesn't dry camp :-))
Thanks,
John
John Taylor
Old 06-06-2012, 10:39 AM   #11
is it 2 or 4 wheel drive?
Pullrite 20.5K
2012 Sierra 365SAQ
Old 06-06-2012, 10:45 AM   #12
It is a 4 wheel drive.
John Taylor
Old 06-06-2012, 11:08 AM   #13
Using the calculator you come up just short on that fifth with a 10% margin and 20% pin, feel free to change things and rerun it, below is the results.
Fifth Wheel Weight Calculator
Gears: 3.73
Bed length: 8 feet
GVWR: 11,500
Front GAWR: 6000
Rear GAWR: 7000
in addition
GCWR 23000
max loaded trailer weight 15200 (for 4x4)
payload 4250 ( 8 foot bed 4x4)
5th Wheel
GVWR 16050
dry pin 2330
Item Qty Units Weight (lb)* Weight (kg)*
Tow vehicle GVWR
Enter Gross Vehicle Weight Rating as provided by tow vehicle manufacturer.
lb
kg
11,500 lb 5,216 kg
Tow vehicle GCWR
Enter Gross Combination Weight Rating as provided by tow vehicle manufacturer.
lb
kg
23,000 lb 10,433 kg
Tow vehicle maximum loaded trailer weight rating
Enter rating as provided by vehicle manufacturer.
lb
kg
15,200 lb 6,895 kg
Tow vehicle maximum king pin weight rating
Enter rating as provided by vehicle or hitch manufacturer, whichever is less.
lb
kg
4,250 lb 1,928 kg
Tow vehicle RGAWR
Enter Rear Gross Axle Weight Rating as provided by tow vehicle manufacturer.
lb
kg
7,000 lb 3,175 kg
Tow vehicle GVW
Enter actual weight (Gross Vehicle Weight) of tow vehicle.
lb
kg
6,720 lb 3,048 kg
Tow vehicle RGAW
Enter actual weight of tow vehicle's rear axle (Rear Gross Axle Weight), without trailer attached.
lb
kg
Fifth wheel trailer GVW (or GTW)
Enter actual weight (Gross Vehicle Weight or Gross Trailer Weight) of trailer.
lb
kg
16,050 lb 7,280 kg
Fifth wheel trailer king pin weight
Enter actual king pin weight of trailer.
lb
kg
2,330 lb 1,057 kg
Safety margin
Enter a percentage (1 to 50) of the tow vehicle′s maximum ratings you wish to leave as a safety margin. Recommended margin is 20%.
Fifth wheel trailer king pin weight percentage override
Leave this box empty for the calculator to use the recommended 25% maximum as the king pin weight. Enter a percentage (1 to 50) to use as king pin weight instead. Recommended range is 15% - 25%.
Calculation Results Weight (lb)* Weight (kg)*
Maximum Trailer Weight
This is the maximum trailer weight based on the most restrictive tow vehicle ratings provided (maximum loaded trailer weight rating).
Trailer GVW exceeds Maximum Trailer Weight. The provided trailer GVW (or GTW) exceeds the calculated maximum trailer weight. You should either lighten the trailer or provide additional information for a more accurate calculation.
15,200 lb 6,895 kg
Maximum Trailer Weight with Margin
This is the maximum trailer weight based on the most restrictive tow vehicle ratings provided, reduced by a safety margin of 10%.
13,680 lb 6,205 kg
Maximum King Pin Weight
This is the recommended maximum king pin weight, based on 20% of the calculated Maximum Trailer Weight.
3,040 lb 1,379 kg
Maximum King Pin Weight with Margin
This is the recommended maximum king pin weight, based on 20% of the calculated Maximum Trailer Weight with Margin.
2,736 lb 1,241 kg
Pullrite 20.5K
2012 Sierra 365SAQ
Old 06-06-2012, 11:40 AM   #14
Gears: 3.73
Bed length: 8 feet
GVWR: 11,500
Front GAWR: 6000
Rear GAWR: 7000
in addition
GCWR 23000
5th Wheel
GVWR 16050
dry pin 2330
Tow vehicle GVWR
lb
kg
11,500 lb 5,216 kg
Tow vehicle GCWR
lb
kg
23,000 lb 10,433 kg
lb
kg
15,200 lb 6,895 kg
lb
kg
4,250 lb 1,928 kg
Tow vehicle RGAWR
lb
kg
7,000 lb 3,175 kg
Tow vehicle GVW
lb
kg
6,720 lb 3,048 kg
Tow vehicle RGAW
lb
kg
lb
kg
16,050 lb 7,280 kg
lb
kg
2,330 lb 1,057 kg
Safety margin
15,200 lb 6,895 kg
13,680 lb 6,205 kg
3,040 lb 1,379 kg
2,736 lb 1,241 kg
Thanks for running the numbers, you just saved me some future grief and probably some money too. This will really help me focus in on what 5th wheel we'll pick out.
John Taylor
Old 06-06-2012, 11:44 AM   #15
You are welcome
save the link to the calculator and you will be able to work yourself through the process, there is also some good tips on matching the TT and TV on that site.
Happy shopping
Pullrite 20.5K
2012 Sierra 365SAQ
