Old 10-17-2018, 08:43 PM   #1
Cardinal 3825 2018
We just got a 2018 3815 FL. It has a washer and drier, stacked in a bedroom closet. I have heard that the bathroom and kitchen gray tank are connected and 40 gallons, the washer has a 40 gallons gray tank and the blackwater is 40 gallons. The fresh water is 60 gallons. Does anyone know if what I just stated is correct? Thank You
whj77372 is offline   Reply With Quote
Old 10-17-2018, 08:52 PM   #2
Not connected. I connected mine
If not camping, I am Sailing
JohnVtx is offline   Reply With Quote
Old 10-17-2018, 09:22 PM   #3
2015 model 3825fl
70 gallon fresh
40 gallon black
40 gallon grey (kitchen sink, bathroom sink, shower)
40 gallon grey (washer)
all separate and not connected
there is a way to connect the two grey tanks so you can get a combined 80 gallon grey tank. but a valterra twist on sewer valve. it twists onto the sewer outlet where you would normally attach the sewer hose. attach this valve and close it. then open the two grey tank valves. they will equalize through there drains behind the valterra valve.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
cardinal
