Old 01-30-2016, 02:03 PM   #1
Cardinal 3875 FB
Can someone tell me about the black and grey water tanks on this unit. I have two black drain handles and two grey handles. I need to know what drain goes into which tank. I only have one wash out connection but apparently two black tanks. This unit has 1 and 1/2 baths. I have called Forest River four times and have not had a call back. Thanks for any help.
Brittontn is offline   Reply With Quote
Old 01-30-2016, 03:50 PM   #2
I had the same issue and the very same unit and here is what I found. Starting from the front of
The Normans
2016 Cardinal 3875FB
2014 Chevrolet 3500HD
snormaniii is offline   Reply With Quote
Old 01-30-2016, 04:21 PM   #3
Starting from the front of the unit, the first (black) handle is the Master (front/full) black tank. Mike was oversprayed with copper colored paint so this was pretty confusing to start with. Also, if you have a washer/dryer it drains into this black tank. Sounds crazy but that is how it was built. It actually helps clean out this tank what with all the laundry soap, etc but you do have to dump it more frequently.
The other large (gray) handle dumps the grey water from the shower.
Inside the storage you find two smaller handles.
The black one dumps the black water from the half bath and that is the tank that the backflush services.
The small gray handle dumps the galley. I don't know for sure but I would guess the half bath sink goes into the galley.
As far as the dump pipes go, the front one is the dump pipe for the Grey water and the half bath black water. The rear pipe is for the galley and master black. As you can tell black water doesn't use just one of the hoses, but both hoses. Again, that's odd to me.
I've labeled my handles and pipes using a labeler and sticking the labels on the side of the RV by the respective handles.
When we took delivery the dealership didn't know any of this so the filled each tank separately and experimented until they figured it out.
Good luck!
The Normans
Old 02-04-2016, 12:39 PM   #4
i have a 2015 3875FB. FR sent me these drawings.
File Type: pdf 3875 FB Tanks and Tank Locations (1).pdf (175.9 KB, 84 views)
File Type: pdf 3875 FB Plumbing and Termination (1).pdf (703.6 KB, 60 views)
lesterw is offline   Reply With Quote
cardinal
