Old 09-16-2016, 04:05 PM   #1
Cardinal or Cedar Creek
Which one is the top of the lineup?
Kiltedpig is offline   Reply With Quote
Old 09-16-2016, 04:15 PM   #2
Jestercyco's Avatar
I looked a Big Horn, Cardinal and Cedar Creek . I liked the Cardinal more, but it is what you like that counts.
Jester
2012 Super Crew 4WD 6.7 PSD
2015 Cardinal 3800 FL
2007 Road King Black Cherry-Hers
2007 Road King Blue-Mine
1979 FXS Hot Rod Shovelhead
Jestercyco is offline   Reply With Quote
Old 09-16-2016, 04:56 PM   #3
I like the ceder creek better
bigger bath room
just bought the 2017 champenge
wire1946 is offline   Reply With Quote
Old 09-17-2016, 06:07 AM   #4
Have you seen the new River Stone line from Forest River, if not check it out.
dblr is offline   Reply With Quote
Old 09-17-2016, 06:11 AM   #5
yes I have seen the river stone at the rv show in hersey pa. nice just about the same layout as the champagne. it has so nice extras .
Old 09-17-2016, 09:14 AM   #6
Jim34RL's Avatar
To me it depends on the dealer and how good he is if you are interested in the Cedar Creek RV or Cardinal RV. The dealer can make buying an RV all the difference between a good experience or bad experience with either model. We went with the Cedar Creek model because there is no Cardinal dealer in the area.
One feature we like in the Cedar Creek model is the outside door, this has a peep hole instead of a full frosted window in the door. This prevents excess light and heat from entering the RV durning the day and helps keep it cool. Do a search and see how many people put in foil to block the excess heat and light that enters through this window in the door, Cedar Creek has eliminate that problem.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 09-17-2016, 12:04 PM   #7
SilverbackMel's Avatar
But what makes you happy! BUT, remember that BLACK draws heat. If you do go that route, I would go full body paint!
Think about summers in Fl or AZ or Vegas. They don't tell you that in a sales pitch.
Get an added 100,000 btu AC for the bedroom vs std 13,000. 😁
SilverbackMel is offline   Reply With Quote
Old 09-17-2016, 11:08 PM   #8
I was really interested in the quality of the build and the materials used.
Old 09-17-2016, 11:12 PM   #9
trbomax's Avatar
Materials are the same,quality depends on time of day and day of week.
trbomax is offline   Reply With Quote
Old 09-17-2016, 11:33 PM   #10
The Estate Edition Cardinals are very nice.
John Taylor
2019 Newmar Bay Star 3609
2018 Cardinal 3350RLX - sold
2013 Cardinal 3030RLS - sold
jtaylor1920 is offline   Reply With Quote
Old 09-18-2016, 05:56 AM   #11
Oakman's Avatar
The construction of the Cardinal vs. the Cedar Creek is completely different, laminated side walls in the Cardinal, hung side walls on 16” centers in the Cedar Creek. Both are excellent units so buy from the dealer that will provide “excellent” service after the sale.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 09-18-2016, 06:21 PM   #12
trbomax's Avatar
"laminated " as in a press or a vacume bag or? What is the exterior material?
Old 09-18-2016, 06:32 PM   #13
Did that take Trilogy's place?
SkipnTerri is offline   Reply With Quote
Old 09-18-2016, 07:01 PM   #14
It's vacuum bonded and the exterior is gel coat.
John Taylor
Old 09-19-2016, 06:37 AM   #15
I would not say replaced the Trilogy as the River Stone is built in it's own factory in Millersburg but would say they just added a new line of product and at 2 levels, one with more options and higher components. Their web site does not yet show the 2 different levels of units, hope they fix it soon.
Old 09-19-2016, 08:45 AM   #16
Oakman's Avatar
More like filled the niche that the Trilogy has vacated
Bob and Joyce
ATU Local 788
Old 09-19-2016, 10:21 AM   #17
trbomax's Avatar
The "hung" walls are gel coat too,but the product is Filon,thin plywood,a layer of resin impregnated fiberglass matt,and gelcoat.My question is , what is the exterior wall material that is vacume bonded (vacume bagged) to the wall frameing comprised of? "gel coat" is a unreinforced,colored polyester resin which can be either orthophalic or isophalic in compossition,the biggest difference being (after cost) its ability tostand up to UV light with out degradeing.
Old 09-20-2016, 06:00 AM   #18
I would agree with this
Old 09-20-2016, 07:20 AM   #19
Jim34RL's Avatar
Have you seen the construction video on the Cedar Creek webpage. Go to Forest River RV manufacture website hit fifth wheel then click on the Cedar Creek. Under the Cedar Creek banner you will see several different subsections one of them is videos click that. There is a YouTube video labeled construction this explains how the Cedar Creek is built. Hope that helps?
Jim W.
Old 09-20-2016, 02:12 PM   #20
checked out the video on the Cedar Creek site but there isn't one for the Cardinal. I wonder which construction method is best for a full-timer. Not sure about the frame for the Cardinal but the C/C has a 10" I beam with a box tube welded to the bottom. What does the Cardinal have for a frame?
cardinal, cedar creek
